Front Lower Control Arm HELP!!!
ok so i replaced my front LCA and as im bolting it together the bolt closest to the engine wont tighten... i feel in the hold and there is a nut sitting in there no where near the hole where the bolt goes... how to i finish this thing???
I can't think of a reason why it wouldn't fit. Pics?
It should be pretty straightforward -- put the bushing in the spot on the underside of the frame, run the bolt through and it will thread in.
Have you tried threading the bolt in without the LCA just to see that it fits and will thread like it's supposed to?
did you bold the LCA to the steering knuckle already??try using a prybar to get it to align right. OH and did you match the new part to the old part?
JW : why are you replacing the lower contorl arms?
i bought some with new ES bushings and im doing the 4x114 brake swap so im doing it all at once. lol i bought a new bolt just to make sure it wasnt the wrong bolt to start with cuz i bought the shell barely put together lol
IggDawg
Nov 20, 2003 06:25 PM
