flywheel
Old Jan 8, 2004 | 11:08 PM
[ iLL ] iNt3GrA's Avatar
Default flywheel
i will b changing the trans on my GSR soon becuase i cracked it and since i have the trans out good time to do a flywheel/clutch im thinking of going with at act 6puck w/ hd and maybe a 10p? flywheel whats a good weight for a all motor teg daily driver and what company
2nd w/ a GSR throttle cable and a Skunk2 IM what so i need 2 bolt the cable down to the IM do i need a type-r cable or just the brackets and do i need 2 reverse the way the throttle opens? thanks
Old Jan 8, 2004 | 11:28 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: flywheel ([ iLL ] iNt3GrA)
I've been running a Clutchmasters 7.5 lb flywheel on my stock GS-R for almost 20K miles now, I absolutely love it.
Old Jan 8, 2004 | 11:43 PM
sPaRk'iT's Avatar
Default Re: flywheel (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I've been running a Clutchmasters 7.5 lb flywheel on my stock GS-R for almost 20K miles now, I absolutely love it. </TD></TR></TABLE>
Cant wait to put my 7.5 CM FW in my b20 Turbo
Old Jan 9, 2004 | 05:40 AM
ggangtong81's Avatar
Default Re: flywheel (sPaRk'iT)
how does it feel when u put the aftermarket clutch?? is it harder to step on it?
Old Jan 9, 2004 | 07:22 AM
Redtail's Avatar
Default Re: flywheel (ggangtong81)
Yeah, the pedal is harder to depress. I have an ACT stage 2 Kevlar with a AASCO flywheel. For daily driving I wouldn't really recommend the 6-puck - especially if you drive in traffic. It makes it much much harder to drive at anything except WOT.
Old Jan 9, 2004 | 08:35 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ggangtong81 &raquo;</TD></TR><TR><TD CLASS="quote">how does it feel when u put the aftermarket clutch?? is it harder to step on it? </TD></TR></TABLE>
My new Clutchmasters Stage 1 clutch felt alot lighter on the pedal when it was brand new vs. my old OEM clutch. Eventually it stiffened up and is about the same as the stock one.
Old Jan 9, 2004 | 08:44 AM
hypa's Avatar
Mine has been good to me too.
After you figure out how to launch it, you'll find that everything from heel toeing, to upshifting is smoother. A light flywheel is a good mod.
Old Jan 9, 2004 | 08:55 AM
damn 7.5?? so ur 1st n 2nd must go so quick, how much did u pay for it?
Old Jan 9, 2004 | 09:08 AM
Community Builder
Default Re: ([ iLL ] iNt3GrA)
It does not really make acceleration faster. It's not like the gears are shorter or anything.
I paid about $650 shipped for both clutch and flywheel from NOPI.
Old Jan 9, 2004 | 09:12 AM
true so what dif did u feel when u put it in
Old Jan 9, 2004 | 12:21 PM
bump
Old Jan 9, 2004 | 01:22 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> iNt3GrA]true so what dif did u feel when u put it in</TD></TR></TABLE>
It revs alot faster, downshifting and rev matching is easier.... however you have to be quicker when upshifting, especially when the A/C is on. All in all it's just more fun to drive.
Mindgamez
Transmission & Drivetrain
Oct 2, 2009 07:40 AM
Your Name
May 5, 2009 11:44 AM
Sic_DA_Nine
Mar 27, 2007 04:39 PM
Teglessb18
Nov 28, 2006 06:12 PM
hammerdgolfer
Aug 26, 2004 12:57 AM
