Fluidyne
Old Jan 17, 2004 | 03:54 PM
integraGSR213's Avatar
New User
Default Fluidyne
i got a fluidyne radiator for my 94 integ gsr, the ac fan does not fit. anyone know if the fluidyne fan is any good or should i go for a different brand, any suggestions.
thanks
Old Jan 17, 2004 | 04:37 PM
coos's Avatar
Default Re: Fluidyne (integraGSR213)
any fan that fits should work fine, with the knew radiator your not going to get that hot
Old Jan 17, 2004 | 06:40 PM
Scooter502's Avatar
Use the Fluidyne fan. I had the same problem. The OEM AC Compressor fan is too thick. Order the thin fan from fluidyne, use their mounting kit and you'll have no problems.
Good radiator choice.
Old Jan 17, 2004 | 06:41 PM
TurboTeG4's Avatar
I got a fal fan and a fluidyne, you still have to do custom stuff as mines is not done yet but probably do it tomorrow. You have to shave the fan down a lot and drill new holes in the metal mount that comes with it as well as make custom brackets to hold the a/c portion.
Old Jan 17, 2004 | 06:44 PM
Scooter502's Avatar
The Fluidyne fan just uses zip ties. I was wondering about the FAL setup. Let us know what you think about them when you're finished.
C
Old Jan 17, 2004 | 07:00 PM
96 Ls lnTeG's Avatar
Default Re: (Scooter502)
It seem like hookin up the ac fan is such a hassle... from what I have been reading.. anyone try spal???
Old Jan 17, 2004 | 07:09 PM
Seedc2's Avatar
Default Re: (96 Ls lnTeG)
arnt fluidyne fans expensive? same goes for fal fans... right?
Old Jan 17, 2004 | 07:40 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scooter502 &raquo;</TD></TR><TR><TD CLASS="quote">The Fluidyne fan just uses zip ties. I was wondering about the FAL setup. Let us know what you think about them when you're finished.
C</TD></TR></TABLE> I have the fluidyne/fal setup. Works excellent, you just have to trim a little bit off where the fan shroud contacts the radiator. But they are costly, mine were about 300, I got them after I was in an accident so I didn't have to pay for them. If i had to pay for fans, I'd just get two autozone slim fans, which I have heard work well w/ fluidynes.
Old Jan 17, 2004 | 08:32 PM
Default Re: (Threatcon13)
stop worryin about fans an get one like mine
Old Jan 17, 2004 | 09:15 PM
hi mom's Avatar
bah, only pussies buy new fans. I used an aluminum welder and made some brackets for my stock fans, works perfect and has lots of clearence for my turbo..
Old Jan 17, 2004 | 09:31 PM
New User
Default Re: (mulldog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mulldog &raquo;</TD></TR><TR><TD CLASS="quote">bah, only pussies buy new fans. I used an aluminum welder and made some brackets for my stock fans, works perfect and has lots of clearence for my turbo..</TD></TR></TABLE> another clown who contributes w/ something irrelevant to make himself feel better.
Old Jan 18, 2004 | 06:49 AM
hi mom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> another clown who contributes w/ something irrelevant to make himself feel better.</TD></TR></TABLE>
nah, on the serious note..
you could go with the fal fan if you want to spend the extra cash, but with some custom brackets you could just mount your stock fans back on like I did, cheaper and it still does the job..
Old Jan 19, 2004 | 10:21 AM
Acronym's Avatar
Ok im about to install my Fluidyne & at the same time im dropping my A/C. Should i even install other fan? i really don't want to purchase a new one to fit. How can i make my stock one fit if i really really need it????
Acronym's Avatar
Default Re: (Acronym)
Custom brackets? how did u do this?
Old Jan 19, 2004 | 10:25 AM
NuclearB18B's Avatar
i've got the fluidyne. when i installed it, both of the stock fans fit. but now that i'm turbo, the fans' won't clear with the turbo in the way. so i've got only the a/c fan (smaller one) on the passenger side of the radiator. works great and i haven't run into any problems yet.
Old Jan 19, 2004 | 12:32 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">stop worryin about fans an get one like mine
So bling.......
me want!
Old Jan 20, 2004 | 07:03 AM
Acronym's Avatar
Default Re: (ha illuminato un)
Since im going w/ a blower u guys think heat wrapping my header will help since so close to fluidyne? I heard heat wrap can help but can also hurt...Fill me in please
Old Jan 20, 2004 | 08:13 AM
Big Teggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraGSR213 &raquo;</TD></TR><TR><TD CLASS="quote">i got a fluidyne radiator for my 94 integ gsr, the ac fan does not fit. anyone know if the fluidyne fan is any good or should i go for a different brand, any suggestions.
thanks</TD></TR></TABLE>
Get a Perma-Cool slim fan. You can get them at http://www.Jegs.com
Old Jan 20, 2004 | 10:39 PM
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
So bling.......
me want!
Bling cost money about $460, It will look good with my New Samco Hoses that just came in
Old Jan 20, 2004 | 10:44 PM
Seedc2's Avatar
whats good about those samco hoses compared to oem?
Old Jan 21, 2004 | 02:05 PM
roadrunner's Avatar
Hayden 12" slim fan at Kragen Auto was $50. No problems with it on my Fluidyne...
Old Jan 26, 2004 | 05:28 PM
Default Re: (kendogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg &raquo;</TD></TR><TR><TD CLASS="quote">whats good about those samco hoses compared to oem?</TD></TR></TABLE>
More For a Bling Factor Handle more Pressure an Temp Plus I had Extra money
Old Jan 26, 2004 | 05:34 PM
oMek's Avatar
i have a used fluidyne ac fan for sale that i got with my fluidyne for my 95 gsr, you have to use the ziptie things that you can get at autozone to hold it on
https://honda-tech.com/zerothread?id=744560
milkypros
Aug 10, 2011 03:17 PM
User 42624
Aug 4, 2006 05:17 PM
6MTV6
17
Jun 22, 2004 07:02 AM
JBBNJ609
Nov 28, 2003 02:13 PM
austrian type-R
Mar 12, 2003 04:31 PM
