fluctuating idle while in P
Old Nov 13, 2006 | 08:08 PM
zephyrantes's Avatar
Default fluctuating idle while in P
hey guys,
brand new owner (bought her today)of a 91 Integra GS here. Was wondering if you could help me out on this one.
The idle likes to fluctuate between 1000-1500 while in "P" for a few good seconds before settling at about 1500rpm. This is after like a 30 min drive (haven't tested it yet on a cold engine). Car idles fine in "D". NO codes.
I'm not familiar at all with DAs, so when I popped the hood, I was quite confused with all the vacuum hoses. I was thinking that this could be a vacuum leak, but the idle does settle at 1500rpm eventually. I did a search here, but I'm just baffled because it does eventually settle and idle smooth. Can someone help me? Thanks
Old Nov 14, 2006 | 09:33 AM
schoedog2323's Avatar
Default Re: fluctuating idle while in P (zephyrantes)
i would check the iacv vacume rountings and the valve itself had the same problem on my civic
Old Nov 14, 2006 | 10:08 AM
crx_88_si's Avatar
unplug the IACV and see what happens. If it stays UP then there's a vac leak somewhere.
if it goes down, replace the IACV.
RinzEG6
Nov 24, 2014 12:02 PM
WhiteTrashedDA9
May 2, 2013 08:40 AM
dc4b20
22
Dec 3, 2012 09:54 PM
ick
Sep 11, 2005 10:46 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
