flame this ls/vtec setup if nessecary?
94 b18b block
50/1000" cylinder hone
82mm NPR pistons (CTR replicas)...they should fit on the ls rods
LS rods/crank
type r oil pump
king main bearings and rod bearings
complete gasket/seal kit
b16a head in mint shape
gsr cams
golden eagle conversion kit
uberdata
arp studs
sound good or gay?
Modified by the.hamburglar at 6:13 AM 12/28/2005
LS rods/crank
type r oil pump
gsr cams
uberdata
arp studs
sound good or gay?
ok, i just went to zealworks and used b16b pistons and it said ill have a 14.2 compression ratio. wont my motor blow fast?
I'm lead to believe that those are some pretty high compression pistons in that setup. You may want to get something a little smaller or go get some way bigger cams, a good intake manifold, some big injectors and plan on running race gas all the time. But other than that you sound like you're on the right track. As said before balance balance balance lol. Rod bolts are a must if your are sticking with stock rods. I don't know how important shotpeening is in your case. I've heard the stock rods hold pretty good power. But better safe than sorry.
14.2:1 is on the right track?????????no way to much compression. im not using race gas so if i bump it down to b16a pistons my compression drops to 13:1. will i be safe on 94 octane?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">14.2:1 is on the right track?????????no way to much compression. im not using race gas so if i bump it down to b16a pistons my compression drops to 13:1. will i be safe on 94 octane?</TD></TR></TABLE>**** yeah 14.2:1 is on the right track if you wanna go fast in an all motor honda. 13:1 is still really high especially if you are at a low elevation. I would probably be shooting for no more than 11.5:1. It would run good on pump gas without having to retard the timing so much you won't make power.
im going to shoot for 12:1 and get a good tune larger injectors.
who makes an ls/vtec headgasket for a 81.5mm bore? all i can find is 81mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">I'm running 12.7:1 compression on my ls/vtec 93 octane, daily driven, putting down 186 whp, its all in the tuning~</TD></TR></TABLE>Running crap gas and retarding the crap out of your timing is no good. I bet you have 20whp just by adding some timing and running 100 octane.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Running crap gas and retarding the crap out of your timing is no good. I bet you have 20whp just by adding some timing and running 100 octane.</TD></TR></TABLE>
What are you talking about 93 octane is plenty good gas for my compression, you know the old muscle cars, the reason they made such high numbers is because they had high compression ratios, 13:1 compression can easily be done on the street with pump gas.
i dunno man that seems pretty high. it looks like most people are running around 11.5:1 on 93 octane
</TD></TR></TABLE>What old muscle cars are you talking about? the 500hp limited edition corvettes that ran 12:5:1 but had to run 100+ octane and still had detonation problems? Given the fact that they had cast iron heads and were carbureted. But that's not what I'm talking about. I'm talking about junk gas we have today meaning you have to run 11.8:1 AFR and 30 degrees of timing just so this 13:1 motor runs ok. That's a lot of lost horsepower. But I'm not gonna argue with you anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">What old muscle cars are you talking about? the 500hp limited edition corvettes that ran 12:5:1 but had to run 100+ octane and still had detonation problems? Given the fact that they had cast iron heads and were carbureted. But that's not what I'm talking about. I'm talking about junk gas we have today meaning you have to run 11.8:1 AFR and 30 degrees of timing just so this 13:1 motor runs ok. That's a lot of lost horsepower. But I'm not gonna argue with you anymore. </TD></TR></TABLE>
I don't wish to argue, i will admit i dont know a whole lot in the tuning area, i just know that my motor is running 12.7:1 compression on pump gas, the motor runs strong, and don't have any knocking problems, and it put down really good numbers, so i know its possible.
everything looks good.. But while you have the motor out, i'd suggest getting the rods shot peened, get some ARP rod bolts as well. and have the crank micropolish and balanced, its worth the extra money for the reliability.
and 13.1 compression can run off pumped gas, but you have to get it tuned real good.. I have a family friend who's runing about 13.1 in his built B20vtec. he uses pump gas (the highest octane we have around here is 91 some places have 92.. no 93).. his car is tuned real good. hes been running it for the last 2 years..
I've seen other people run 13.1 on pump gas.. its all in the tuning.
Modified by viet_boi_racin at 4:05 AM 12/30/2005
b18b1 - je pistons 9.2:1 - eagle hp rods (3/8's arp rod bolts) - knifed crank - 950$ - GE ls/vtec ki
caspers_hatch
Dec 18, 2005 07:51 AM
MaxBoost
20
Jul 7, 2003 11:50 PM
