Few problems with the r
Subscribe
Feb 20, 2009 | 08:50 AM
I just got an 99 jdm itr half clip from japan Motor trans ecu sup. Are in. They went in a 96 ls. Now my problems are the abs light is on, will that stop when I put the itr axles and brakes on? And my c.e. Light is on I have the test pipe with the o2 senor port and it's still on I tried to pull up codes and nothing comes up. And it only comes on when the car is warm and my vtec doesn't work till the lights on. Please help I searched trying to fix the problem myself And can't figure it out.
Reply 0
Feb 20, 2009 | 11:03 AM
Re: Few problems with the r
Quote: I just got an 99 jdm itr half clip from japan Motor trans ecu sup. Are in. They went in a 96 ls. Now my problems are the abs light is on, will that stop when I put the itr axles and brakes on? And my c.e. Light is on I have the test pipe with the o2 senor port and it's still on I tried to pull up codes and nothing comes up. And it only comes on when the car is warm and my vtec doesn't work till the lights on. Please help I searched trying to fix the problem myself And can't figure it out.
try posting in the ITR section of the forum
Reply 0
Feb 20, 2009 | 11:45 AM
the 96 jdm itr did not have abs if i remember right. i actually have no idea if our ecus control abs. normally cars have stand alone abs modules. if you left your LS abs and everything intact nothing should have been effected unless it is the JDM ecu that does not have the abs feature. i wonder if a US p73 ecu would cure your problem? find out if the ecu and abs are in any way connected.
Reply 0
Feb 20, 2009 | 12:21 PM
It's 99 itr and they do have the abs on the axles I was thnking p28 ecu chipped could solve both problems. But people say changing to that ecu is dumb.
Reply 0
Feb 20, 2009 | 12:22 PM
Not the R!
Reply 0
Feb 20, 2009 | 02:10 PM
Quote: try posting in the ITR section of the forum
This is an Integra LS with some ITR parts. It belongs here in the Integra forum.
Reply 0
Feb 21, 2009 | 07:34 AM
Pull the ABS codes and they will tell you why the light is on. Are you using the ITR cluster?
Reply 0
Feb 21, 2009 | 06:38 PM
Quote: the 96 jdm itr did not have abs if i remember right. i actually have no idea if our ecus control abs. normally cars have stand alone abs modules. if you left your LS abs and everything intact nothing should have been effected unless it is the JDM ecu that does not have the abs feature. i wonder if a US p73 ecu would cure your problem? find out if the ecu and abs are in any way connected.
there IS a seperate abs controller, it's in the right 1/4 panel underneath the plastic.
Reply 0
Subscribe
