Exhaust Rust Question
Old Feb 27, 2003 | 08:11 AM
TerribleOne's Avatar
Default Exhaust Rust Question
Hey,
I recently bought a 98 GSR and it came with a greddy power extreme exhaust on it. I jacked the car up yesterday and found that from the back the pipe that goes into the resonator is all rusted around the connection, this is the reason I believe that it chooses to rattle sometimes at around 3k rpm. Wll my question is, where do I buy just that section of exhaust (resonator to cat)? Or could I use one of these exhaust repair kits Ive heard about. Thanks
Old Feb 27, 2003 | 08:14 AM
Fuuma0083's Avatar
Default Re: Exhaust Rust Question (TerribleOne)
take it to a muffler shop and see if they can get the rust off and smooth out everything or just have them make you a new pipe. But the rattling could be caused by the heat shield, so you should check that as well.
romeo619romeo's Avatar
just sand it down a little with some sand paper and spray it with high temp paint should help
Old Feb 27, 2003 | 08:33 AM
emr88's Avatar
Rust by itself may not be why you hear the rattling. More than likely the resonator itself is scraped up right? If it is, it's probably broken up inside and that is what is causing the rattling, my RS*R did this between 2.5-3.5k and it turned out the resonator had broken up inside.
Old Feb 27, 2003 | 05:29 PM
Default Re: Exhaust Rust Question (emr88)
Well Im gonna really jack it up tomarrow, I only did one side yesterday and didnt find anything, yeah I was kinda suspecting the heat shield, it seems to not rattle sometimes and then it does some others so I dont think the resonator is messed up, well at least I hope not, Ill post tomarrow thanks for the advice though, Ill problebly sand and seal that rust
Old Feb 27, 2003 | 05:42 PM
The Factor's Avatar
id check the heat shield too...lots of gsr owners have this problem.
ShinyNewPenny
13
Feb 3, 2008 05:09 AM
rotascircuit
Nov 26, 2007 08:48 PM
xionl1350
Feb 23, 2007 03:34 PM
litterbox
Jul 26, 2005 04:14 PM
missinghubcabs
Apr 1, 2003 03:57 PM
