Exhaust install
Old Feb 9, 2004 | 10:06 AM
B18Redline's Avatar
Default Exhaust install
What is necessary for an exhaust install? I am putting a stock exhaust system back on and wanted to know if I can reuse the old bolts and if I would need any gaskets or flanges?
Thanks!
Old Feb 9, 2004 | 10:11 AM
Tweakmeister's Avatar
Default Re: Exhaust install (Redline07)
The stock exhaust system consist of 5 bolts/nuts.
2 (plus springs) for the B-pipe to rear Canister connection (and a donut gasket that should be fine)
and
3 nuts that attach to the B-pipe to cat connection with a gasket ($.89 from Autozone...I have an extra here).
The bolts/nuts all rust and are cheap enough to make buying new ones worth while.
From there you just hang the exhaust on the rubber hangers...4 (5?) in all.
Old Feb 9, 2004 | 10:17 AM
B18Redline's Avatar
Default Re: Exhaust install (Tweakmeister)
Thanks, so all I'll need is 3 new bolts and a gasket?
Old Feb 9, 2004 | 10:23 AM
Nihilation's Avatar
Two bolts w/springs for the axleback to b-pipe. Three bolts and nuts to the cat, with a 2" gasket.
*Interesting though...my 00-01 GSR b-pipe only used two bolts to connect to the cat. My 94-99 GSR b-pipe uses three.
tony
Apr 1, 2019 02:28 PM
EJ25er
Nov 21, 2013 12:54 PM
deviant1
14
Apr 9, 2003 12:39 AM
