Engine temp problems.
Old Oct 5, 2020 | 08:02 AM
Shmoe2011's Avatar
Default Engine temp problems.
So I just changed my thermostat last winter, just changed my engine coolant temp sensor. My engine still goes cold after driving and letting it warm up. Note: this really only happens when it gets colder, I dont have an issue during the summer. Also my coolant system has no air bubbles.
Thanks in advance.
Old Oct 5, 2020 | 06:14 PM
aw614's Avatar
10 Year Member
Loved
Default Re: Engine temp problems.
Did you use an OEM thermostat from honda?
Old Oct 6, 2020 | 05:41 AM
Shmoe2011's Avatar
Honestly didnt think I had to use an oem one. But I'll give that a try.
Old Oct 8, 2020 | 11:13 AM
wunfstgsr's Avatar
Loved
Community Favorite
Yea use a OEM thermostat from Honda and bleed the radiator again with the front jacked up high and the heat inside the cabin turned to full high! wait till both hoses turn hot and fans turn on then put the radiator cap back on and lower the car and drive.
