Engine Overheating... and... heater stops working?
Engine Overheating... and... heater stops working.
So the obvious prob would be a lack of coolant... nope... I have tons of it
The overflow is almost full
and... there is coolant on the top of my rad... like its busting out of there
Any ideas what is wrong, could it be the thermostat?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic »</TD></TR><TR><TD CLASS="quote">So the obvious prob would be a lack of coolant... nope... I have tons of it
The overflow is almost full...</TD></TR></TABLE>It's possible for the overflow bottle to be full while the radiator isn't. Did you open the cap & look?
Fan not coming on... Jumper the wires for your fan switch to see if that makes the fans run. If they run, bad fan switch. If they don't, look for fuses, relays, wiring, or a bad motor.
u might also want to check to see if ur radiator has a crack along the top near the neck, my radiator did that and sprayed coolant all over the engine bay, but it never overheated. just a possibility
hotcivicsi
11
Apr 9, 2009 06:19 PM
