Engine Noise....?????
Old Sep 10, 2002 | 03:34 AM
PainfulTeg's Avatar
Default Engine Noise....?????
Ok, does anyone else hear an odd engine noise when they start they're car after it's been warmed up? After I drive for a while, and turn the car off, when I start it back up I can hear like a frictiony sound coming from the head, sounds like the cam lobes aren't getttin enough oil so it makes a little noise for about a second or two,then it will go right away, the car runs perfect otherwise. NO oil consumption or burning.....I just can't tell what the hell it is.....
Old Sep 10, 2002 | 04:20 AM
Regular Series's Avatar
Default Re: Engine Noise....????? (PainfulTeg)
Probably just valvetrain noise...Tegs have noisy tappets anyway, but when was the last time you had your valve lash adjusted?
Old Sep 10, 2002 | 07:41 AM
Full Race EG's Avatar
Default Re: Engine Noise....????? (risingson77)
I hear the same noise as soon as I start my car. I was told it was that ABS. No big deal it is just anoying thats all.
Old Sep 10, 2002 | 09:22 AM
Heh...well, I have no ABS...so it must be my valves.
Old Sep 10, 2002 | 08:19 PM
PainfulTeg's Avatar
Default Re: Engine Noise....????? (IntegraLStuner)
definitely NOT the abs, that is very distinguishable.....did the valves about 25K ago...
I'll try that and see what happens
Old Sep 10, 2002 | 09:22 PM
Well, valve adjustments should be ~every 30k. More if you wind on it. (Which means everyone )
[Modified by risingson77, 1:23 AM 9/11/2002]
RNbuilt
Acura NSX
Jul 9, 2008 04:21 PM
ek4h
Apr 5, 2007 05:19 PM
djgruesome
Jul 5, 2006 05:42 PM
Mikizzle
Nov 21, 2003 08:01 PM
ludeslip
Nov 6, 2002 04:48 PM
