Engine doesnt stay warm
Old Dec 15, 2008 | 04:26 PM
drmix's Avatar
Icon3 Engine doesnt stay warm
Just bought my DA a few days ago and noticed that it never stays warm when im driving. If I let it warm up while parked it gets to normal temperature until I start driving then it goes all the way to the C on the gauge. If I stop at a stoplight it starts going back up. Any ideas on what it could be? I just replaced the thermostat and that didnt help.
*Thermostat replaced
*Fans arent stuck on
*Isnt the cluster because the heat on vent is only hot when up to the middle mark
Old Dec 15, 2008 | 06:44 PM
Ruben19's Avatar
is your coolant temp sensor
Old Dec 16, 2008 | 06:10 AM
drmix's Avatar
Wouldnt my car still be getting warm but just showing up wrong on the cluster? It still doesnt blow hot air unless its been sitting. I start driving and the air gets colder
Old Dec 16, 2008 | 06:21 AM
The G2 Racer's Avatar
Air in the system?
Low coolant?
Full rad or half rad?
Old Dec 16, 2008 | 07:02 AM
CompanyFlow's Avatar
Air in the system would cause it to overheat. Unless you physically aren't feeling hot air come out when the car is moving, then its the temperature sensor.
Old Dec 16, 2008 | 07:16 AM
Jas9848's Avatar
ITS THE THERMOSTAT
its stuck open. replace it
Old Dec 16, 2008 | 08:05 AM
itr#1334's Avatar
Originally Posted by Jas9848
ITS THE THERMOSTAT
Correct. Its cheap and easy to replace. Will fix the problem.
Old Dec 16, 2008 | 08:31 AM
Mashimaro's Avatar
yup, i agree with the above posts. it sounds like your thermostat. did you replace it with a brand new one?
Old Dec 16, 2008 | 09:19 AM
DcLs's Avatar
ITS THE THERMOSTAT
yup thermostat stuck open
Old Dec 16, 2008 | 09:47 AM
NosShootinHonda's Avatar
I have the same exact problem, I'll try to replace my thermostat later today or early tommorow.
Old Dec 16, 2008 | 01:01 PM
drmix's Avatar
Yeah I replaced it with a brand new one and it didnt change anything
ALDJ253
Mar 4, 2014 03:42 AM
JaguarS4R
Honda Civic (2001 - 2005)
12
Feb 28, 2010 04:12 PM
732xghost
Aug 23, 2009 08:48 PM
b_serious
Nov 7, 2005 11:28 PM
Stevorh
13
Feb 2, 2005 04:06 PM
