which engine is better?
Old Mar 16, 2007 | 10:50 PM
95egcivic's Avatar
Default which engine is better?
i got my 95 ls stolen, and found just the shell. ****** thieves, anyways i have to start from scratch, so i dont know to put in a b18b1 with a vtec head or just a b18c1, any suggestions?
Old Mar 16, 2007 | 11:12 PM
integrawow's Avatar
LSVTEC = money left over
B18C1 = no money left over
This should let you know what i'm talking about:
http://www.hmotorsonline.com/s...30008
Old Mar 16, 2007 | 11:29 PM
dvp's Avatar
dvp
Default Re: (integrawow)
LSVTEC=needs more love and will not last as long
B18C1=will last much longer
Old Mar 16, 2007 | 11:46 PM
integrawow's Avatar
Default Re: (dvp)
Before this thread goes any further, we need to know what your goals, expectations, plans, and intentions are for the motor that will be installed.
What I mean is if you are going for reliability, then you may want to go with a GSR. On the other hand, if you want to save a few bucks and have a motor that will out perform (YES, OH YES, IT WILL BURY A F**KIN GSR POS MOTOR, however, you may want the gsr tranny. LOL).
The reason why you'll out run the GSR is because of the money you'll have left over. You'll be able to buy cams, pistons, intake manifold (or a hondata ecu instead). That's why!
NO, I DON'T NEED A CLARIFICATION FROM ANYONE, BECAUSE IT'S A COMMON SENSE SCENARIO. You'll have a little more than a grand left over which can go into BC3 cams and stuff like that. If you take it easy on the motor, and put it together properly, then it should hold up okay just like any other motor. I know that there are probably a few people out there that may have had bad luck with it, but the other millions who didn't have bad luck with it are spanking GSR's as we speak. LOL
I don't mean to bash GSR's or anything like that, but if you'll sit down and actually add up everything, then you'll realize that I speak the truth.
Good luck!
Old Mar 16, 2007 | 11:58 PM
dvp's Avatar
dvp
Don't forget about tuning. That motor will need it.
I'm not a big fan of the LSVTEC motor. Power, sure but reliability pretty much suck.
Old Mar 17, 2007 | 12:11 AM
integrawow's Avatar
In an Integra, a fully swapped H22a will cost nearly $200 less than that of a GSR. It's hard to believe isn't it? But a GSR swap isn't cheap, no matter what way you look at it. You could nearly go out and buy another car with a GSR in it for the same amount of money that it would take to swap in a GSR.
Dollar per horsepower, you'll lose with a GSR.
Old Mar 17, 2007 | 12:41 AM
Jimmy's Avatar
Global Moderator
Best bang for the buck right now, would be to order a B20B from passwordjdm.com right now..
they're like $599.00 for a longblock or two for $999.99.. Buy a distributor and find a tranny cheap and you'll be set.. Even putting out a LITTLE more TQ then the stock LS.
Old Mar 17, 2007 | 03:49 AM
tomlinson619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">LSVTEC = money left over
http://www.hmotorsonline.com/s...30008 </TD></TR></TABLE>
im sure LSVTEC set ups will cost more than a c1 motor.. there are other things u need for an LS V conversion to make it run just as hard
Old Mar 17, 2007 | 05:35 AM
integrawow's Avatar
Default Re: (skunk2 VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2 VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
im sure LSVTEC set ups will cost more than a c1 motor.. there are other things u need for an LS V conversion to make it run just as hard </TD></TR></TABLE>
Well, i'm pretty f**kin sure that it would if I were to go out and buy the most expensive sh*t on the market. We're talking about a complete GSR engine, tranny, and ecu, not just the motor. By the time you get it in the car and get it running correctly, you've sunk over $3500 into it. An LSVTEC setup shouldn't cost within $1000 of a GSR swap. Additionally, it would be an even greater variance depending on which parts the buyer already has. Therefore, by the time the buyer equals his investment in his LSVTEC to that of a STOCK GSR, he/she should bury a GSR.
People also need to grow some *****, because there are alot of people who purchase a kit instead of machining the head themselves when mating it to an LS block. Also, how overly expensive could a $150 set of brand new P30 pistons be? I mean, it's not like someone is going broke over it. Then, around here, it's roughly $50 to have the new pistons mated to a set of connecting rods. Then you'll need a head gasket set which runs in the neighborhood of $75 to $95. There are other costs, but no where near the cost of a GSR swap.
Look, beating a GSR isn't that hard considering the amount of money that someone SHOULD have left over. No matter how you look at it, a GSR will always be a GSR, EXPENSIVE.
Let's try not to complicate things, OKAY!
Old Mar 17, 2007 | 06:14 AM
soundFX's Avatar
my friends selling his b18c1 and tranny for like 2k. they really arent that expensive
Old Mar 17, 2007 | 06:55 AM
IntegraDOHCter's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Best bang for the buck right now, would be to order a B20B from passwordjdm.com right now..
they're like $599.00 for a longblock or two for $999.99.. Buy a distributor and find a tranny cheap and you'll be set.. Even putting out a LITTLE more TQ then the stock LS.</TD></TR></TABLE>
Good idea. You can also get a p8r head for pretty cheap, and some PHK (b2oz higher compression) pistons,throw some crower cams and tuning...you got an all motor beast,...
Old Mar 17, 2007 | 07:12 AM
illdb8's Avatar
Default Re: (IntegraDOHCter)
stay away from the ugly k series. I dont care if its faster, its UGLY
Old Mar 17, 2007 | 07:38 AM
s2kdre's Avatar
Default Re: (UTAHDB8)
just get a type r its worth the money.
Old Mar 17, 2007 | 08:34 AM
LSTEG98's Avatar
ls-vtecs DONT suck and depending on where u get it done and how,,, it could last long with no problems just need to get it done right and get it done from someone who knows how to do it
Old Mar 17, 2007 | 09:07 AM
IntegrasAreBest's Avatar
^ exactly. an ls-vtec motor built right will last as long as it is taken care of and not beaten to hell. If I were in your shoes I would save for the gsr or type R swap.
Old Mar 17, 2007 | 09:09 AM
LSTEG98's Avatar
put it this way how much u looking to spend?
Old Mar 17, 2007 | 09:29 AM
forumnoobie's Avatar
Default Re: (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">LSVTEC=needs more love</TD></TR></TABLE>
lol
Old Mar 17, 2007 | 11:11 AM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraDOHCter &raquo;</TD></TR><TR><TD CLASS="quote">
Good idea. You can also get a p8r head for pretty cheap, and some PHK (b2oz higher compression) pistons,throw some crower cams and tuning...you got an all motor beast,... </TD></TR></TABLE>
exactly, i just picked up a b20z with a p8r head, slapped a b16 tranny on there with bolt ons it is so much fun to drive. Not to mention a bad *** budget build.
Old Mar 17, 2007 | 11:50 AM
slammedNslowLS's Avatar
didnt have time to read all replys so im just going to post my opinion. i say B1 block, B16 head, and B16 tranny (short gear ratio)... then go line up with a GSR and lemme know what happens!!! lol
Old Mar 17, 2007 | 11:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UTAHDB8 &raquo;</TD></TR><TR><TD CLASS="quote">stay away from the ugly k series. I dont care if its faster, its UGLY</TD></TR></TABLE>
ugly??? riiiiiiiiite. im glad people by motors because they are pretty. i think someones upset because they cant afford one
Old Mar 17, 2007 | 12:20 PM
doood's Avatar
been there done that
Default Re: (slammedNslowLS)
did you just get whooped by a stock k swapped civic in your bolt on's teg?
Old Mar 17, 2007 | 12:27 PM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
did you just get whooped by a stock k swapped civic in your bolt on's teg? </TD></TR></TABLE>
probably some ex girlfriend who gave him herpes driving her new b/f's k20 EF!!!!
Old Mar 17, 2007 | 05:25 PM
98GSRDC2's Avatar
Default Re: which engine is better? (95egcivic)
if you thinking about saving money go lsv, but if you have a higher budget go b18c1 or h22a
Old Mar 17, 2007 | 08:16 PM
integrawow's Avatar
I'm glad to see that the original poster has opted for an LSVTEC setup. LSVTEC w/P30 pistons,s
from hmotorsonline.com, for just over $150 brand new.
Old Mar 18, 2007 | 05:06 PM
integrals3's Avatar
do the b18b1 with a b16 vtec head
