Electrical Problems
Old Oct 3, 2010 | 04:16 PM
  #51
mrchevez's Avatar
Default Re: Electrical Problems
Thanks a lot everybody, I'll do that as soon as I can and I'll let you guys know how it goes. I'll do the hid first than hopefully that solves it or not ill do the headlights and fog lights
Old Dec 4, 2010 | 06:16 AM
  #52
parsapour's Avatar
Dears,
I faced with the case some how in contact with the ground connections, the symptom is that Battry Indicator light is remain ON while switch is turned OFF and Key is removed, and it gets OFF when switch is turned at pre ignition position (before engine Ignition) and remains OFF after engine is started, I just returned from repair shop for Head gasket change, I wonder what can cause such problem, is it sign of worn Alternator Or bad wiring Or weak ground connection? Can it harm the alternator?
Thanks for lead and appreciate your guides. ACCORD 1991 EXi Sedan
Parsapours@aol.com
Old Mar 7, 2012 | 01:15 AM
  #53
Qwane Wave's Avatar
fris off i have a 95 honda accrod lx v-tech and what causes a shortage i put a new battery and new started and new altintor in and its still diein while i drive wat else can causes a short and how do i fix it and anybody have any idle what can be causes the shortage???
91hatchproject
Mar 19, 2010 03:01 AM
nyzd79
Audio / Security / Video
Mar 16, 2008 12:12 PM
nyzd79
Mar 14, 2008 09:20 AM
nub_pwn
Sep 16, 2006 08:21 PM
redteg1
Apr 8, 2002 02:43 PM
