ECU code 67?
can someone tell me what ecu code 67 (P0420 Catalyst System Efficiency Below Threshold) means? i just got the car and its throwin this code. The car also cam with an aftermarket exhaust. could that be the problem? thanks.
your cats gone...you can try feelin you exhaust for good flow...or if you have access to a lift...try hitting the cat(car off), if it rattles, its for sure bad. tip: cats dont go out by itself...the prob is usually upstream like towards the motor...maybe o2 sensor...injector
