ECU AND ABS CODES HERE!
Just thought id add this link to further assist with actual pics for people doin this for the first time to see what it looks like....http://www.team-integra.net/se...ID=34
I think it describes how to read the ABS codes about mid way down the list from what I just read.
My question: Once you make a repair, will the light go out by itself if you have fixed the problem, or do you need to reset the light some how, and then see if it comes back on to find out that you did not fix the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legal Bill »</TD></TR><TR><TD CLASS="quote">I think it describes how to read the ABS codes about mid way down the list from what I just read.
My question: Once you make a repair, will the light go out by itself if you have fixed the problem, or do you need to reset the light some how, and then see if it comes back on to find out that you did not fix the problem? </TD></TR></TABLE>
The ABS light will not illuminate again unless another fault condition is detected. Pull the ABS fuses in the underhood fuse box by the ABS unit to clear the codes. The ABS computer stores the 3 most recent fault codes.
Ok i have an 89 crx exclusive, does anyone know the abs codes for this year? it started off as a fuse and then the cv joint sensors which have been both replaced (had to take it to honda themselfs but cost me more than my pay cheque to get it fixed
), and now the light goes off but after about a min and a half of driving down the road the light comes back on, my abs computer in the boot as an LED in a little glass hole, when i put the ignition to on, it flashes 3 times all about 1 second long with about a 2 second pause, and then it just stops and doesnt flash again, can anyone help?
This is weird. My blue connector has 3 wires going into it. Brown, blue, & yellow wire. Anyone else have this?
edit: nevermind. It was tucked up under the dash more and not in the green casing. I have 2 plugs.
Modified by Thorgs at 12:02 PM 3/23/2008
Hi, I need help please.
I just bought a 94 Integra LS "mid swap" B16A, OBDI, P30 ECU manual trans.
Here is the problem, it will not start. It turns over at the normal rate. I have fuel psi and pulse at the injectors, their is just no spark. I have tried a known working dist and still nothing. There is power to the dist but no signal from the ECU.
I tested for cel and got 20, I think that is for ELD, not sure if info is correct. In my Haynes manual, it shows pix but I cannot make out where the test point is??
I would be very grateful for any help. I have been messing with it for almost 2 weeks, on and off, when I can. Thank you
