Drivetrain Prob
Old Jun 29, 2005 | 09:52 AM
FULL-REV's Avatar
Default Drivetrain Prob
So my teg doesn't move
Prob is the car goes into gear but doesn't move anywhere. I can hear a sound coming from the tranny area that something is moving in there. I think it might be the clutch but i'm not really sure. Car just revs in gear and i could the mph go up with the revs.
I already bought a stage 1 clutch 6 puck
Anything think its something else?
Old Jun 29, 2005 | 11:46 AM
FULL-REV's Avatar
bumppp helppp
Old Jun 29, 2005 | 12:34 PM
IN VTEC's Avatar
Default Re: Drivetrain Prob (hondaevo)
If the speedometer is increasing and the clutch is engaged, but the car's not moving, then I'd look at the axles or the splines in teh differential that output to the axles. More than likely tho, one of the CV joints is busted.
Old Jun 29, 2005 | 01:33 PM
FULL-REV's Avatar
Default Re: Drivetrain Prob (IN VTEC)
if one of those are busted what exactly do i need to replace?
Old Jun 29, 2005 | 06:55 PM
IN VTEC's Avatar
Replace the axle that has the broken CV joint.
Old Jun 30, 2005 | 03:17 AM
Dee A Nine's Avatar
But he has to make sure that's it though. I bet he wouldn't wanna waste his money on something that wasn't it... know what I mean?
Old Jun 30, 2005 | 04:24 AM
IN VTEC's Avatar
Default Re: Drivetrain Prob (Dee A Nine)
Get under the car and try to turn each of the axles. If any part of the axle doesn't turn when you rotate it, then it's snapped inside of the CV boot.
If it's the differential splines (either on the diff or on the axle), then you'll only be able to tell by visual inspection after you remove one or both of the axles.
CarBug
Jun 9, 2016 02:58 PM
david76008
Oct 10, 2008 08:34 AM
krystne89
19
Mar 23, 2008 02:30 AM
overtwo
Feb 21, 2008 10:05 AM
Blaze45
14
Jul 28, 2003 08:26 PM
