Dome light...
Old Nov 19, 2006 | 08:21 PM
ziggen243's Avatar
Default Dome light...
...is not working!!! Well, it works but will take up to 5 min to turn on, after i open the door. Sometimes the damn thing wont work at all. When the light is turned on manually, it seems to flicker and dim. I replaced the bulb, but to no avail.
I'm no mechanic and dont pretend to be. I would just love for the one thing that works on my car to in fact WORK.
Any advice is greatly appreciated.
Old Nov 19, 2006 | 08:53 PM
kynetik's Avatar
Default Re: Dome light... (ziggen243)
have you tried replacing the fuse?
Old Nov 20, 2006 | 10:17 AM
HGZ's Avatar
HGZ
maybe you have a loose wire or connection somewhere..
Old Nov 20, 2006 | 11:41 AM
8YourV8's Avatar
If the light flickers on and off when you turn it on, then it's not your fuse; otherwise it would just stay off. As H.G. suggested above, you most likely have a loose connection somewhere.
Old Nov 23, 2006 | 05:21 PM
ziggen243's Avatar
Default Re: Dome light... (H.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.G. &raquo;</TD></TR><TR><TD CLASS="quote">maybe you have a loose wire or connection somewhere..</TD></TR></TABLE>
I will check that!! Thanks for the advice. My car will be crappy no more!!!!
lilazndrag0n02
Feb 3, 2013 06:37 AM
mortificationrock
Apr 22, 2008 12:44 PM
slickyo
Mar 16, 2006 11:06 AM
b18dude
Apr 9, 2005 09:47 PM
upstate
Jul 21, 2004 12:46 PM
