doing timing belt
Hey guys,
I'll need to replace my 97 RS timing belt soon. Here's a list of parts I'lll be ordering, am I missing anything? Timing belt AC belt Alt belt PS Belt Water pump do I need to replace any pulley? Oh, the teg will be at 70k soon, I'll also be changing Coolant, fuel filter cap and rotor [Modified by SamC, 8:15 PM 3/3/2003] |
Re: doing timing belt (SamC)
valve cover gasket
cam and crank seals tensioners and pulleys case of beer https://honda-tech.com/forums/images/smilies/emwink.gif best to do these when you got everything apart.... https://honda-tech.com/forums/images/smilies/emthup.gif [Modified by NeoGSR, 2:29 PM 3/3/2003] |
I was about to tell you about an Emissions recall in which Honda agreed to replace most tune up parts for free and check the emissions system, but its only for cars with 75k-150k. You may want to keep that in mind tho for the next time you want to change plugs, cap, rotor and wires. They also threw in a free oil change.
http://www.4acura.com/service/updates/98-031.asp Mike |
Re: doing timing belt (RacerMike)
I was about to tell you about an Emissions recall in which Honda agreed to replace most tune up parts for free and check the emissions system, but its only for cars with 75k-150k. You may want to keep that in mind tho for the next time you want to change plugs, cap, rotor and wires. They also threw in a free oil change. http://www.4acura.com/service/updates/98-031.asp wow, that'd been nice if it covered my car too....that's quite a savings.... https://honda-tech.com/forums/images/smilies/emthup.gif Mike |
Re: doing timing belt (NeoGSR)
interesting....im gonna have to see if i can get these parts free
Hey guys, I'll need to replace my 97 RS timing belt soon. Here's a list of parts I'lll be ordering, am I missing anything? Timing belt AC belt Alt belt PS Belt Water pump do I need to replace any pulley? Oh, the teg will be at 70k soon, I'll also be changing Coolant, fuel filter cap and rotor [Modified by SamC, 8:15 PM 3/3/2003] Also, inspect your crankshaft pulley for cracks. The pulley on my GSR had cracks so I replaced it. I also put on a new crankshaft pulley bolt. Have fun ! some tips here: https://honda-tech.com/zerothread?id=421701 |
| All times are GMT -8. The time now is 02:27 AM. |
