Do I need a camber kit ?
Old Mar 19, 2003 | 09:45 AM
jaM3s Bond's Avatar
Default Do I need a camber kit ?
Im getting a good amount of uneven wear on the inside of my front tires. The rear of my car is wearing pretty evenly (rear is not as dropped)
Do you think I need a camber kit for this drop or do you think just a full alignment will do the trick?
Old Mar 19, 2003 | 09:51 AM
IC x Prince's Avatar
New User
Default Re: Do I need a camber kit ? (X EneMy X)
you can't tell until you get an alignment (unless you're hella slammed). get that done first and if you need, one then get one.
Old Mar 19, 2003 | 09:52 AM
jaM3s Bond's Avatar
Default Re: Do I need a camber kit ? (UltraPrince)
Yea, I might already need front tires, I guess ill just run through these then get some falkenz
Ill take it down to wheel works today.
Old Mar 19, 2003 | 10:32 AM
neo1z's Avatar
What are you dropped on -- H&R?
Old Mar 19, 2003 | 10:34 AM
jaM3s Bond's Avatar
Default Re: Do I need a camber kit ? (neo1z)
Naw Im on full coilovers.
Old Mar 19, 2003 | 10:49 AM
jaM3s Bond's Avatar
While im at it, do you think I could fit a 215/50 with that drop?
Old Mar 19, 2003 | 10:53 AM
illi Adik's Avatar
Get an alignment first.
Old Mar 19, 2003 | 12:24 PM
Brett's Avatar
Default Re: Do I need a camber kit ? (Jackson4Door)
I'm dropped on coilovers where the top of the tires are just barely tucked under the fenders. I had a full alignment done and my tires are still worn out after a couple months. Get a front camber kit and do the washer trick on the back.
On a side note; does anyone know if when an alignment shop says "align to factory specs" is that setting the toe-in to zero?
Old Mar 19, 2003 | 12:38 PM
jaM3s Bond's Avatar
Default Re: Do I need a camber kit ? (Brett)
Well Maybe a camber kit is what I need. Im thinking about getting one anyway.
Anyone recomend a brand? I guess the skunk one is as good as any huh? Pretty well priced too.
Old Mar 19, 2003 | 01:13 PM
jaM3s Bond's Avatar
Well after reading about the skunk2 slipping Im going to go with an ingalls. Im going to head to the spot and get an align done.
Old Mar 19, 2003 | 03:49 PM
Danger's Avatar
lower it more
Old Mar 22, 2003 | 02:29 PM
htownteg's Avatar
ingalls squeek and skunk2s slip...so what camber kits are left to get?? first i was going to get a ingalls then i heard they squeek..now i hear skunk2s slip?
ErrRexShun
Suspension & Brakes
Mar 23, 2009 04:45 AM
Beeda
Dec 13, 2007 05:28 PM
xunkn0vvnx
Oct 5, 2005 10:16 AM
Nader_D
Jul 14, 2003 06:09 PM
junglerunna
Nov 18, 2002 05:05 PM
