Do I need alignment?
Old Apr 26, 2006 | 04:56 PM
Just_LS's Avatar
Default Do I need alignment?
OK just have rotors turned and brake fluid bleeded and now car is shaking on freeway. Around town seems fine and braking seems fine. Re-torque wheels twice and still shakes on freeway - do I need an alignment?!
Old Apr 26, 2006 | 05:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: Do I need alignment? (Just_LS)
You may need an alignment, but the problem you're describing sounds more like a wheel balance issue.
Old Apr 26, 2006 | 05:07 PM
sponge's Avatar
I vote for a re-balance as well. It's an inexpensive a fix.
Old Apr 26, 2006 | 05:08 PM
Beeda's Avatar
i had the same problem but mine was due to the fact the my alignment was so bad that the whole inside of my right tire was completely bald and it had made some big ball on the inside so everytime i drove it felt like my wheel was about to fall off
then finally i was on the freeway and it popped on me..i thought it was my axle or soemthing when to the tire shop and yeah that tire was ugly
Old Apr 26, 2006 | 05:10 PM
Silent_Destruct's Avatar
my rims were bent which caused mine to be shaky....just hope its not that... and also if its really low, i have that problem right now i need an alignment before it balds my new tires and i got me some h&r springs to install woot
Old Apr 26, 2006 | 05:11 PM
Just_LS's Avatar
Default Re: Do I need alignment? (Padawan)
The car tracks fine before I did the brake job, so I don't think it will be a wheel balance issue?? Though, I did rotate the front and rear tire... Anyone?
Old Apr 26, 2006 | 05:16 PM
the rear tires might have not been balanced...so when u rotated them it cause the unbalanced to go upfront...u wont really notice them if they are unbalanced in the back....thats the prob right there
Old Apr 26, 2006 | 07:41 PM
DynastyRacer22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just_LS &raquo;</TD></TR><TR><TD CLASS="quote">The car tracks fine before I did the brake job, so I don't think it will be a wheel balance issue?? Though, I did rotate the front and rear tire... Anyone?</TD></TR></TABLE>
that might be the problem since the front of ur car is heavier and it put more pressure on your front tires..i had this problem before and i checked all the air on my tires made sure they were balanced and i was good to go good luck tho
oh yeah also it did this to my friends car in his gsr around town its ok until he hit the freeway and accel from about 60mph+ it started shaken then he replaced his axels and it drive perfectly fine now
cepsenior
May 23, 2007 05:39 PM
Ideal
Jul 20, 2006 04:44 PM
hmongboyLS
May 4, 2006 10:41 AM
chimchimm5
14
Nov 17, 2005 06:21 PM
jared703
Jul 27, 2001 04:04 PM
