DIY ICEBOX
Old Oct 9, 2005 | 08:43 PM
sumyungguy's Avatar
Default DIY ICEBOX
Heres my DIY Icebox
First (dont ask how I got this) I modified a tacoma Injen intake arm to go from the tb to the box.(i think you can use a gsr sri if you cut down the filter side)
Then I cut the small stock peice that comes out of the bottom of the box that goes from oval to round.(its actually a little bit lager than 3 inch alum pipe) and slid this jackson intake arm, from god knows what, into the cut oval.
Then after the vertical pipe I needed to go around the radiator and tow hook.. I used high heat flex hose(used to relocate exauhs fumes,, like from a dyno)
its difficult to see... sorry i didnt feel like removing my splash guards
After making a U turn around the radiator and tow hook I used a small slice of 3 inch pipe to finish off the flex hose.. cut out the block off in the stock bumper where the factory fog light would be.
Finally I installed the Comptech UNI filter.
now the question you guys keep askin ... did it make power???
yes but not much
I straped it to the dyno ran three times without the top of the box on and three with the top on. in a time span of 30min
<U>Made</U> an average of 2.75 hp from 3000-6500 and 1.5 up to 8500
and 3 lbstrq 3000-5000 and 2.5 lbstrq 5000-7500 same for the last 1000rpm
Now real world figures would probly be larger cause wind speed increases.. we have pretty good fans on the dyno but the street would have much much more air flow.
This whole thing was done to keep the lovely california police men happy when they ask you to pop the hood and to save my *** some cash..this was after my civic was jacked..lost over $10,000 so my teg mods were on a very tight budget. I on a regular basis I use the factory arm and a k&n filter. but now that im in new mexico where theres no such thing as smog I run the alum. arm and UNI filter.
When I run the UNI filter its not a perfect seal on the back of the filter but I still manage to suck up leaves from time to time so theres really no need to seal the back of the filter.
Here you can barly see where it comes up to the front
Modified by sumyungguy at 11:51 PM 12/5/2006
Old Oct 9, 2005 | 08:54 PM
iH8RICERZ's Avatar
Default Re: DIY ICEBOX (sumyungguy)
sweet... so with the top of the air box off, did it make more power as if the top of the box was on?
Old Oct 9, 2005 | 08:57 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: DIY ICEBOX (iH8RICERZ)
You should spray the piping that shows through the front BBQ black or flat black.
Would be 10x better
Old Oct 9, 2005 | 09:07 PM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">sweet... so with the top of the air box off, did it make more power as if the top of the box was on?</TD></TR></TABLE>
its better with top on.
there was thread about using hose from bumper(outside) to intake box. and just comptech icebox type. it turns out temps are same.. i dont know why.lol but ya
Old Oct 9, 2005 | 09:12 PM
BlUeDC2nEr's Avatar
Default Re: DIY ICEBOX (JunkyDC2)
NICE DIY!
That's a good idea making an ice box using an aftermarket short ram and a stock air box.
reminds me of the comptech setup.
Old Oct 9, 2005 | 09:15 PM
sumyungguy's Avatar
and its an 4hp & 5lbstrq between the stock arm w/k&n filter and the alum. arm and UNI filter.. the UNI in the +.. thats only because I have cams, opened up gsr manifold, and jdm ITR header and cat
Modified by sumyungguy at 12:07 AM 10/10/2005
Old Oct 9, 2005 | 10:11 PM
kevpotts's Avatar
Default Re: DIY ICEBOX (cnaman)
just curious, why did you use the jackson intake instead of just that stock black pipe... you know that goes from oval to round? set up looks sweet, good job man
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnaman &raquo;</TD></TR><TR><TD CLASS="quote">
i mean, with the top on, loks like theres barely any room for air get in. only on the bottom.
...hence the piping going down to the bumper. Have you seen a real icebox before?
Old Oct 9, 2005 | 10:12 PM
sumyungguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnaman &raquo;</TD></TR><TR><TD CLASS="quote">really dont know how u gained HP. looks like there isn't any room at all for the filter to suck up air.
its pulling in colder air and the size of the box is actually compressing it... im not saying like a turbo or a blower..but what do both of those do??? compress and force the air into the motor... this is slightly compressing the cold air the motor is pulling in,, witch is gold on a naturally asperated motor.
Old Oct 9, 2005 | 10:13 PM
db8xc1x39
Guest
Posts: n/a
for putting in some work
Old Oct 9, 2005 | 10:17 PM
sumyungguy's Avatar
Default Re: DIY ICEBOX (kevpotts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevpotts &raquo;</TD></TR><TR><TD CLASS="quote">just curious, why did you use the jackson intake instead of just that stock black pipe... you know that goes from oval to round? set up looks sweet, good job man</TD></TR></TABLE>
I used the jackson pipe because when it came to attaching the flex hose it was at the perfect height and it was the same diameter as the flex hose, and it looked like it would work better because the stock pipe coming out of the bottom of the box had like baffles in it.
Rok_Stok
May 18, 2009 03:51 PM
Rok_Stok
May 18, 2009 01:41 PM
SPOONfdEK
Aug 15, 2003 10:16 AM
R rated
Nov 14, 2002 05:23 PM
MotorMilitia LS
Oct 17, 2002 10:37 PM
