Difficult cold starts
Old Jan 22, 2003 | 07:15 PM
vtec69's Avatar
Default Difficult cold starts
When i go to start my car when its cold i need to give it gas and let it idle at 2000 rpms for a min or so
if i let go of the gas the car stalls
i thought it was the battery so i got a new one but it still didnt start right up
anyone have any ideas???
TIA
-Brian
Old Jan 22, 2003 | 07:27 PM
IN VTEC's Avatar
Default Re: Difficult cold starts (vtec69)
You didn't take the Fast Idle Thermo Valve outta the coolant loop did you?
Old Jan 22, 2003 | 07:33 PM
vtec69's Avatar
Default Re: Difficult cold starts (IN VTEC)
The who what and the where what know?
WHat is that and where is that???
-Brian
Old Jan 22, 2003 | 07:44 PM
IN VTEC's Avatar
If you've got a pre-'98 throttle body (is it '98?), then the FITV is found under the mouth of the throttle body. It's mounted to the throttle body and has two nipples on opposite sides (front/back facing) for coolant lines.
Old Jan 22, 2003 | 07:56 PM
vtec69's Avatar
i did not disconnect that
-Brian
Old Jan 22, 2003 | 08:55 PM
IN VTEC's Avatar
I don't know what the hell I was thinking. If the valve is there, but the coolant lines weren't routed, it still wouldn't have problems cold idling. The FITV would still be "cold" and allow extra air in. The problem with the coolant lines not being routed is that it wouldn't rev down the idle, even if the engine was warmed up.
Maybe the valve got stuck in the closed "warm" position. It's strictly a mechanical device.
You also might wanna check the IACV and idle adjustment screw.
Edit: The IACV's 2Pin connector might not have been connected. I've never tried starting a cold engine with the IACV disconnected, but on a warm engine, it'll bog pretty badly until it stabilizes the idle itself. However, if the IACV wasn't connected, it would exhibit a rough/low idle after it was warmed up....as well as a CEL (Code 14).
And, I've never tested the idle adj screw, but it would probably have to be almost to all the way closed before it would affect idle that bad.
[Modified by IN VTEC, 12:02 AM 1/23/2003]
P. Hunter
Apr 7, 2013 05:46 AM
Key Enzyme
Feb 15, 2013 06:08 AM
EFstyle
Jul 29, 2008 07:09 PM
si_motor_spt
16
Oct 14, 2007 04:57 PM
ramtyper19
May 16, 2005 10:07 AM
