difference between ls and gsr catback system?
Old Feb 23, 2003 | 10:06 AM
avividmemory's Avatar
Default difference between ls and gsr catback system?
I'm just curious, because I found a good deal on a gsr system...but my car is an ls...so what exactly is the difference...btw its the 3" for turbo
TIA
Old Feb 23, 2003 | 10:09 AM
fivespeedintegra's Avatar
Default Re: difference between ls and gsr catback system? (SpoolinLS)
midpipe length is different between ls and gsr. the gsr has a shorter midpipe (if i'm remembering correctly). if you tried to bolt the gsr exhaust up to an ls, the pipe wouldn't reach the cat, it'd be like 4" too short.
Old Feb 23, 2003 | 12:43 PM
Lord Helmet's Avatar
Default Re: difference between ls and gsr catback system? (fivespeedintegra)
yep! that's I learn from my friend's gs-r. my old greddy exhaust would fit my other friends ls but it was too short on the gs-r; about 3-4 inches shorter.
Old Feb 23, 2003 | 12:46 PM
Default Re: difference between ls and gsr catback system? (sleeperciv)
can't you just get a shop to extend the pipe though? correct me if i'm wrong, but i think someone on the baord even posted a picture of theirs done that way.
Old Feb 23, 2003 | 12:49 PM
so wait, you just completely contradicted that statement...he said then ls piping is longer, and you agreed but then said the ls piping was too short on the gsr
so if the ls piping is longer than the gsr piping how was it too short on the gsr, wouldnt that make it too long...
Old Feb 23, 2003 | 12:58 PM
00VTEC's Avatar
TIA
it'll fit if the gs-r catback is from 00-01 integra. (94-01 LS, 00-01 gs-r, type-r catbacks are all interchangeable)
if its from pre 00 gs-r, you just gotta extend the pipe.
[Modified by 00VTEC, 5:00 PM 2/23/2003]
Old Feb 23, 2003 | 01:04 PM
sharkey65a's Avatar
yea the second quote makes sence, but if the midpipe was shorter than the exhaust system would be longer. in wich case you might be able to cut it and reatatch what is needed to bolt it on. because its rare im guessing the gsr midpipe is longer than that of the ls.
Old Feb 23, 2003 | 03:08 PM
my bad
I was trying to say that on my civic coupe the greddy exhaust I had fits my friends integra ls but it won't fit the gs-r because when I bolt up the exhaust it was about 3-4 inches shorter. sorry I wasn't watching what I type down.
Old Feb 23, 2003 | 03:44 PM
98integraLS's Avatar
To get the Gsr(94-99) catback to fit u will need to cut it about 3-4 inches.
here is why:
*pic borrowed from team-integra.net
SurferX @ t-i.net-
"Note that all brackets connect at the same point. The LS and Type R A-pipes are equal in length and have the primary O2 sensor before the cat so that's why you can fit Type R header applications onto an LS. In 2000, the GS-R switched to an A-pipe the same length as the LS.
[Modified by 98integraLS, 1:40 AM 2/24/2003]
Old Feb 23, 2003 | 04:05 PM
my bad
its cool, i just confuse easily
and thanks for that picture, it helped
MopdiT
Oct 22, 2007 06:11 PM
Jay Blazed
Aug 26, 2006 01:05 PM
95integraSE
Oct 6, 2005 09:50 AM
StolenTeg
Jun 28, 2004 07:43 PM
tC_Dragon
Oct 18, 2002 11:15 AM
