Difference between jdm b16a cam gears & LS cam gears?
Hi guys im just wonderin if it theres gonna be any changes if i replace my stock ls cam gears to jdm b16a cam gears ??? all reply will help thank you... would it gain power ???????????
I'm almost positive they're the same. It wouldn't be worth your time to swap them out. If you want power, buy cams first... then get some adjustable cam gears.
nope no difference. the only reason people change there cam gears are to get adjustable ones...and the b16a cam gears arent.
