did a compression test...b18c1
Old Sep 4, 2014 | 02:52 PM
DCiFound's Avatar
Default did a compression test...b18c1
Hi all, I did a compression test on all 4 cylinders. Cyl # 1,2,3 show 220 steady, but cyl# 4 pressures up, but doesn't hold as the needle slowly drops. did it 4 times with same results.
Am I doing something wrong? If not, what else could it be?
Old Sep 4, 2014 | 03:11 PM
Runnerdown's Avatar
Default Re: did a compression test...b18c1
Probably just the hose connection or valve is leaking. It's a one way valve so that you can manually release the pressure after you are finished with each cylinder.
Old Sep 7, 2014 | 10:48 AM
fcm's Avatar
fcm
Old Fart
If 1,2 and 3 are good, then my guess is either a valve or rings on cylinder 4, check valve lash on cylinder 4, may just have a "tight" valve. 94
Old Sep 7, 2014 | 10:43 PM
DCiFound's Avatar
It was user error on his part. The pin wasnt sitting correctly on his tester. We did it again and it held at 215.
However, i do need to adjust my valve lash, since im hearing a slight ticking noise
nemesis25
Jan 12, 2015 04:17 PM
89civichb
11
Mar 10, 2009 08:26 AM
Christopherian1982
Jan 13, 2009 12:09 AM
moesrex
May 23, 2006 08:55 AM
