DC and DA brake caliper differences?
Old Jan 5, 2006 | 01:33 PM
transpar_nt's Avatar
Default DC and DA brake caliper differences?
I've got a brand new set of brakes for a DA that I want to put on my EG. I know the front knuckles won't work properly on my car. If I were to buy a pair of bare knuckle/hub assemblies from a DC would the calipers bolt on? I searched and found out that the rear calipers are the same, and rotor sizes from 90-01 non-R integras are the same, but nothing was mentioned about front calipers.
Also, if they do bolt on, is there a difference in piston size between the DC and DA front calipers?
PS - Why is there no "brakes" forum?
Old Jan 5, 2006 | 01:40 PM
projectTeG's Avatar
im not sure on the calipers but i do believe the rotors are the same
Old Jan 5, 2006 | 01:43 PM
Default Re: (projectTeG)
Check.
Bump for caliper info.
Old Jan 5, 2006 | 01:49 PM
projectTeG's Avatar
https://honda-tech.com/zerothread?id=883196
this should solve your problem
Old Jan 5, 2006 | 01:54 PM
Thanks man!!
So basically the calipers are the same, but I would still need 90-93 pads?
BTW, what did you search for when you found that thread?
jksmith
Oct 14, 2010 04:38 PM
vti2
Oct 23, 2008 08:26 PM
Trench_Rat
Jan 7, 2006 03:18 PM
GReatEDDY
Jun 10, 2004 02:41 PM
ChiBoy
Feb 1, 2002 06:05 PM
