dashboard light dont work
Old Oct 7, 2010 | 03:13 PM
el lucas's Avatar
Default dashboard light dont work
i have a 94 acura integra... the light and the gauges on the dashboard doest work...i checked the fuses and are good...i need help thanks
Old Oct 7, 2010 | 04:37 PM
fcm's Avatar
fcm
Old Fart
Default Re: dashboard light dont work
Are you talking about the "dash illumination lights" the ones that come on with the first "click of the light switch?
Do you have a multimeter or 12V test light?
Do you have an aftermarket stereo in the dash? 94
Old Oct 7, 2010 | 04:57 PM
el lucas's Avatar
the dash illumination lights its goog..im talking about the engine light,brake light,seatbelt light,the speed gague the fuel gague,tempeture gagues,and the clock dont work at all...
yes i have a aftermarket stereo... but let me tell u i painted my car and i take fenders,front bumper and doors....after finished with the paint i installed evrything back. and then no lights...
Old Oct 8, 2010 | 05:59 AM
fcm's Avatar
fcm
Old Fart
OIC...
You say you checked the fuse, fuse 15 - 10A, [hot in run and start] in under dash fuse box?
Did you test the fuse or just eyeball it?
If you tested the fuse or replaced it with a new or known working fuse, [swap it with another fuse of the same size] then you will need to pull the cluster and test the yellow lead at the cluster plug, there will be two (2) yellow leads, both are from fuse 15. 94
Old Oct 9, 2010 | 02:28 PM
el lucas's Avatar
good new bro..... i pulled the cluster out and one of the plug wasn t good..... soo i fixed ans evrything work good now.............. thank bro for your time and help
ilovemydc5
May 22, 2007 12:45 PM
soon2bspoolin88
Nov 14, 2006 05:28 PM
fastnnasty06
Audio / Security / Video
Oct 28, 2006 02:36 PM
caspers_hatch
May 24, 2005 09:49 AM
sgT
Nov 18, 2002 09:58 PM
