Dash light question?
I have a 96 Integra, and im looking at the 94 interior fuse diagram, now my problem is. My dash light doesnt come on, the fuses are good (if there the same as the 94-96) and the bulds appear to be fine. Is there something else I could be missing?
Modified by tr!gga at 9:04 PM 9/27/2007
Yes the dimmer is up, and the heater control lights and the SRS/Check engine/Turn signals all work... Just the damn dash light is blah.
Which fuse box? The bozo I bought the car from removed all the fuse box'es, and all the wiring is messed up... Also is there suppose to be a switch that connect's to a main switch on the cluster? Let me try and get a pic to better explain it.
oooo man, i dunnoo bout all that, best advice, take it to an electrician, if its all done like that, sounds like someone tried to do a wire tuck ore something.....good luck mang
Alright last time messing with this thing before I take it to a mech. Can someone give me the diagram for the interior wiring harness for the gauge cluster. Or something like that.
Well I know I got a short somewhere.... This kid didn't know what the hell he was doing with the wiring, but it's like not getting direct feed to it what so ever.. I know my VSS is working because my maintance require light turned and, I and think that run's thru the VSS? Just the speedo and dash light is taking a poop on me.
Yeah it's not the bulbs that's the first thing I checked. Im going to replaced the speedometer itself and see if my old one took at dump, (I hope) if not then back to rewiring!
Well I finally got my dash light to work. All the way in the back there was a ground gone, So fixed that and poof it work's now. Now my next step is the damn speedometer!
