Dash e-brake light on when down. Why?
Old Mar 26, 2003 | 09:07 AM
CBR600OnTop's Avatar
Default Dash e-brake light on when down. Why?
It seems almost every morning when I start up my car I will put the e-brake down and he light on the dash that sais BRAKE is still on and then will go off 15 minutes later or so. It does not effect the drivability of the car but its just really annoying. Anyone else have this problem and how did you fix it? Thanks
Old Mar 26, 2003 | 09:46 AM
KoRE's Avatar
Default Re: Dash e-brake light on when down. Why? (TegTuner)
maybe you need some brake fluid? worth a shot takes 10 sec to check
Old Mar 26, 2003 | 10:04 AM
982drLS's Avatar
i got that same problem.... it usually happens in the morning when my car is cold, and when i start driving it'll go off... i usually just push the button and move the e-brake up and down a little and it'll go away.. or when ur driving just tap the brakes real quick and it sometimes goes away... its hella annoying though
Old Mar 26, 2003 | 10:11 AM
Eva01's Avatar
Default Re: Dash e-brake light on when down. Why? (982drLS)
Try adjusting the tension of the parking brake. CLICK HERE for a link.
[Modified by Eva01, 7:11 PM 3/26/2003]
Old Mar 26, 2003 | 10:15 AM
YumVTEC's Avatar
check brake fluid level.
Old Mar 26, 2003 | 10:17 AM
95 Gizzer
Guest
Posts: n/a
Default Re: Dash e-brake light on when down. Why? (YumVTEC)
That happens on my Nissan mini van when I go around corners too fast. It's pretty annoying, but not something to worry too much about
Old Mar 26, 2003 | 10:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dash e-brake light on when down. Why? (95 Gizzer)
That's a telltale sign that you're low on brake fluid.
Old Mar 26, 2003 | 10:59 AM
SMZ GSR's Avatar
Default Re: Dash e-brake light on when down. Why? (PatrickGSR94)
as everyone and there mothers say...brake fluid
98type_r's Avatar
New User
if its not the brake fluid then its the tension of the cable, adjust that and you'll be fine.
mine does the same thing but i'm waiting to get my new brakes installed before i make any adjustments to the cable
Old Mar 26, 2003 | 12:38 PM
shadowdawn's Avatar
Default Re: Dash e-brake light on when down. Why? (tie par)
I'll put $20 on brake fluid level, I JUST fixed this problem Just add a bit till its AT not over the MAX line on the container.
Old Mar 26, 2003 | 02:15 PM
MooreBoost's Avatar
It happens to me occasionaly. I just got used to it. I suppose its just a faulty sensor.
gmoore
Old Mar 26, 2003 | 02:17 PM
acinteg94's Avatar
That happens all the time at my job when we pull up the e-brake to do spins in neons and escorts. but yeah fluid or the cable is probably the cause.
Old Mar 26, 2003 | 09:11 PM
Default Re: Dash e-brake light on when down. Why? (acinteg94)
Im going to try that brake fluid and i'll let you guys know how it turns out. thanks
Old Mar 27, 2003 | 10:14 PM
The One Upper's Avatar
Where do you work? LOL
1996 Honda Civic DX
Dec 9, 2008 12:47 PM
neo702
Jul 26, 2006 01:09 PM
dohcvtecpower
Sep 3, 2005 06:27 AM
H22A4 Prelude
Dec 16, 2004 11:33 PM
4g4me
Oct 14, 2004 03:50 PM
