dart block
hey i just recently learned about dart blocks. i was just curious what are the advantages and disadvantages of them? what is so special about them? also how do you choose what bore size you want? thx in advance.
+ Dart B18 block has stock deck height, std 81.5mm bore, optional 84.5mm bore (accepts 95mm stroke)
+ Dart B20+ Block has extra tall 8.900" (226mm) deck height, 84.5mm bore for increased displacement.
+ Manufactured from aerospace quality C355-T6 virgin aluminum alloy for maximum strength, durability.
+ Replaceable ductile iron dry sleeves are fully supported to reduce bore distortion and enhance ring seal.
+ Closed deck design increases bottom end strength and minimize bearing bore distortion.
+ Extra large water jackets increase coolant circulation around cylinders.
+ Standard pistons oil sprayers reduce piston temperatures to extend life and prevent detonation.
+ Dart Blocks use stock components including oil pan, oil pump, water pump, alternator and timing belt tensioner.
+ 86mm Maximum bore, 95mm Max stroke
Spade
Dec 21, 2001 11:33 AM
