damn integra windows
Old Jun 25, 2010 | 03:05 AM
bigsmoketeg's Avatar
Default damn integra windows
im having problems with my passenger window it will role up but not down i have a new regulator and motor.i also switched the switch on both sides .it get power to go up but not down for some reason any help would be appreciated .i live i a town with 120 degree heat and im sweating my ***** off
Old Jun 25, 2010 | 03:51 PM
hybrid90's Avatar
Default Re: damn integra windows
Pics of your sweaty ***** or you're lying!
Did you check G2IC.com? There's a few threads concerning slow/stuck windows.
Here's one.. hope this helps.
http://forums.g2ic.com/showthread.ph...ttles-in-doors
Old Jun 25, 2010 | 06:49 PM
fcm's Avatar
fcm
Old Fart
MM&Y of the car would help.
My guess is it is a wiring problem, Honda/Acura power windows, [wiring] is pretty simple, "polarity reversing ground at rest" same as the power door locks.
If the window will go up, the problem is not the motor, [regulator] it has to be the wiring, so first thing to do is test the wiring at the motor plug, both should test as grounds, [switch no moved], then turn on the ign. and test both leads again, once with the window switch in the up position, one lead should test as a ground and the other as 12V+, now with the window switch in the down position, again one lead will be a ground and the other 12V+, just opposite of when switch is in the up position, [polarity reversing].
Let me know what you find. 94
crxpwr1
Jun 2, 2013 05:12 AM
lilvietboy
Oct 15, 2008 09:52 PM
vtechnomaniac
Aug 1, 2007 02:47 PM
tomauto
11
May 14, 2006 04:56 PM
Mikeman191
Apr 18, 2004 06:50 PM
