da teg fuel pump problem NEED HELP!
Old Feb 6, 2008 | 12:30 PM
chadwick67's Avatar
Default da teg fuel pump problem NEED HELP!
i have a 92 teg, and I just got done building my motor, and i got it into the car. when i try and crank it over there is no fuel coming to the filter, and no noise coming from the pump at all. i've already replaced the relay and i still get nothing. for my car do we have to drop the tank to get to the fuel pump? or can we get to it under the back seat. I have no other transportation so any help would be great. thanks!
Old Feb 6, 2008 | 12:37 PM
mr.beeks's Avatar
Default Re: da teg fuel pump problem NEED HELP! (chadwick67)
read here..
https://honda-tech.com/zerothread/2216706
Old Feb 6, 2008 | 12:57 PM
chadwick67's Avatar
Default Re: da teg fuel pump problem NEED HELP! (mr.beeks)
that link really didn't tell me anything. i don't have any screws on the top of the fuel pump plate so i either need to drop the whole tank, or twist or tun the plates
Old Feb 6, 2008 | 01:10 PM
DA_9's Avatar
Yea i think u gotta drop the tank. I have the same problem, went to dealership and looked at their service manual (expletivein twice or maybe three times the size of the Haynes) and it looked like we gotta drop the tank. Its different for integras than civics. the 91 integra and the 91 civics gotta be done the same, the 94 integras and the 92 civics are under the rear seats. good for them, bad for us.
Old Feb 6, 2008 | 03:30 PM
chadwick67's Avatar
Default Re: da teg fuel pump problem NEED HELP! (DA_9)
so your sure that we need to drop the tank? i would hate to do all that work and not need too. Even if we drop the tank though how do i get the pump out? do i try and turn the tabs with a screw driver or what?
Old Feb 7, 2008 | 07:52 AM
chadwick67's Avatar
bump, where is the fuel pump main relay located? if that was shot would the check engine light still stay on right before you start the car and not go off after the 3 seconds like its suppose too?
z1gary
Mar 24, 2013 02:22 PM
Homotor
Oct 19, 2009 04:14 PM
Louis53123
Dec 23, 2005 03:28 PM
