cv joint ?
Old May 31, 2002 | 05:29 PM
95gsr's Avatar
Default cv joint ?
i was so close in removing the cv joint today i could not remove the lca. i am pist i have a broken cv boot and i need to replace it. has anyone done this? replaced the boot themselves. thanks in advance.
Luis
Old May 31, 2002 | 05:38 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: cv joint ? (95gsr)
replacing the boot is a bitch.. just replace the whole axle.. you wont regret it!! I did it about 1.5 weeks before my car got totaled.. i replaced both axles because one CV joint went bad.. its not that hard if the axles come out like they are supposed to! Good luck man!
Old May 31, 2002 | 07:06 PM
jetdriven's Avatar
Default Re: cv joint ? (GSR-OwnzJo0)
drive it with the torn boot until it begins to click LOUDLY when turning. I drove my 91 Eagle talon for two years like this, finally replaced them when it would click with the steering wheel 1/2 way turned. The worst you can do is damage the outer joint, which wont matter because you return it for a core.
Old Jun 1, 2002 | 09:46 AM
The-LS's Avatar
How can you tell when the CV joint is bad? And how much did it cost to replace the axles? Should anything else be changed while swapping out the axles? thaks
Old Jun 1, 2002 | 10:11 AM
H-T Poker champion
Default Re: cv joint ? (RayRay000)
You can tell the CV joint is bad when you hear a thudding noise when you are remaining at a constant speed or slowing down.. aka braking. Its not a hard noise to miss.. I bought aftermarket axles.. they were 150 a peice. Acura Stage-1's.. they were great.. You can get a remanufactured axle for 50 - 100 bucs.. its not hard to replace if the old axle slides out like it should! Good luck
Old Jun 1, 2002 | 11:00 AM
The-LS's Avatar
Okay, because right now I hear a intermittent thud/loud click noise from the front right side of my car when I accelerate or decelerate. I was guessing its probably the CV joint, I just wanted to make sure that’s what it was because I don't got much money to be swapping parts that MIGHT be my problem. Where did you get the "Acura Stage-1's" axles? Does anyone recommend any other type of axles or have a reason to favor OEM vs other brands? Thanks
Old Jun 1, 2002 | 11:40 AM
ndustryalGSR's Avatar
Check out The Driveshaft Shop.
Old Jun 1, 2002 | 12:20 PM
Sean K's Avatar
Default Re: cv joint ? (ndustryalGSR)
Sorry for the getting off topic, but are there any autocrosses in Austin? I'm moving there in the fall and I was just wondering.
Old Jun 1, 2002 | 12:32 PM
BranzLS's Avatar
Default Re: cv joint ? (Sean K)
Acura took care of my cv boot under warranty... took em about an hour to do this, very simple! Good luck doing it yourself
EJ8 GSR-T
May 17, 2007 07:19 PM
tekkynikality
Oct 27, 2004 02:12 PM
G1 TEGGY
Aug 17, 2004 04:34 PM
projecthybrid04
Sep 26, 2002 06:38 AM
