ctr cams on gsr?
Old Nov 24, 2002 | 09:15 AM
JDM DC2's Avatar
Default ctr cams on gsr?
is it safe to put on ctr cams on a 95 gsr with cold air, header, exhaust....will i bend my valves? will i break anything? i also got a chipped comp. will this hurt my motor or will i run hard? does ctr cams even make a difference?
Old Nov 24, 2002 | 09:31 AM
Nighthawk GS-R's Avatar
New User
Default Re: ctr cams on gsr? (JDM DC2)
youll be fine. You dont really have to change anything. just dont REV past 8000.
Old Nov 24, 2002 | 09:48 AM
Dirty GS-R's Avatar
New User
Default Re: ctr cams on gsr? (Nighthawk GS-R)
Old Nov 24, 2002 | 12:50 PM
JDM DC2's Avatar
Default Re: ctr cams on gsr? (Dirty GS-R)
does it pull hard?
Old Nov 24, 2002 | 12:53 PM
piatl7il77's Avatar
You should feel the difference.
Old Nov 24, 2002 | 12:56 PM
fiebru1119's Avatar
Default Re: ctr cams on gsr? (piatl7il77)
it will pull all the way to redline.. however you will feel a slight bog between 4500-6000 rpm from an improper vtec engagement setting. to correct this you need a VAFC or another vtec controller
Old Nov 24, 2002 | 01:25 PM
ITRinEJ1's Avatar
Default Re: ctr cams on gsr? (fiebru1119)
stock p72 computer should redline at 8200 or 8400 i forgot but u can take it up to there no problems!!
however since u already have the head out might as well upgrade the valvetrain to portflow inner/itr outter valve springs combo. good for up to 9k, and u dont even need to go up to there with CTRs!! and stock retainers are fine up to that point also. that's my current valvetrain setup with Toda As and i set my rev limit at 8800
Old Nov 24, 2002 | 03:20 PM
threatcon13's Avatar
New User
Default Re: ctr cams on gsr? (ITRinEJ1)
you can rev all the way up to the stock limiter w/ no problems. (why would changing out cams alone make your rev limit lower than stock? )
Old Nov 24, 2002 | 04:56 PM
dc24me's Avatar
As long as you don't plan on revving past your stock redline, you will be fine. If you can afford it, upgrade the valvetrain at the same time, since these are from a a car that redlines higher. If you can't afford it, just stick with cam gears, a VAFC and tuning.
Old Nov 24, 2002 | 04:58 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: ctr cams on gsr? (dc24me)
I have the ctr cams and they made peak power at 7500rpm. So you dont need to go pass 8000rpm
Old Nov 24, 2002 | 05:12 PM
dc24me's Avatar
Default Re: ctr cams on gsr? (comptechgsr2000)
I have CTR intake cam only and I lost peak with it. I pulled a 157 with just IHE last year, 155 this year. I need a VAFC. It was on a different dyno and other factors came into play, but the cams are useless without tuning in terms of top end.
The CTR redlines at 8200 rpm. If you could get your GSR to pull safely to 8200 or even higher with CTR cams, imagine the power you can get?
Old Nov 24, 2002 | 09:18 PM
JDM DC2's Avatar
can i just dump these cams in? or do i need the springs also? and how much is head work usally? i have a chiped p28 i can rev to 9g but i think im only gonna go to 8200 the most dunt wanna take a chance on bending a valve
Old Nov 25, 2002 | 12:22 PM
JDM DC2's Avatar
bump*
Old Nov 25, 2002 | 12:25 PM
jabroni95gsr's Avatar
i can't believe no one has said this yet.
DO A SEARCH!!!!!!
Old Nov 25, 2002 | 12:35 PM
berkel's Avatar
Default Re: ctr cams on gsr? (jabroni95gsr)
OK,
I'll bite.
Check this out: http://www.geocities.com/dynocenter/95gsr_fb.html
Way back when I actually owned a Honda. 173 HP and 124 TQ with CTR intake cam, stock valvetrain. Field or VAFC make a big diff. Also need cam gears, I think I was at +2/-2.
Good luck!
FB
Old Nov 25, 2002 | 01:28 PM
iH8RICERZ's Avatar
Default Re: ctr cams on gsr? (berkel)
i have a ctr intake cam in my 94 gsr w/ 148k on my motor.......i have all bolt ons and chipped ecu like you, as well as adj cam gears. I noticed a difference, especially in the top end.....as soon as you hit vtec, it jumps to redline a lot quicker than stock gsr cams. Just be sure you dont rev past 85k!
99ekb18b
Sep 12, 2008 08:55 PM
94IntegraLs04
May 10, 2006 08:38 PM
crush
Jun 19, 2005 09:53 PM
Sohc Driver
Aug 9, 2002 07:43 PM
IgniteTeg
May 19, 2002 12:23 AM
