crower 404 cams
hey guys iam looking to get some work done to my b18b1. what i have soo far is 64mm TB, 3inch CAI, intake manifiold headers 2.5 and a 2.5 inch exauste . now what i want to know is will i be able to run crower 404 cams with upgrade valvesprings and retainers on a daily driven b18b1. oh and iam not geting high compression pistions. send me some feed back and let me know if this set up is safe. thanks one more thing iam geting the motor tunned
Why would it be not good for daily driving with those cams? they are far from agressive compared to some other cams out there. The cams with upgraded valve springs and retainers will help you make power well and I believe it will raise your redline to 7500rpm
You will be fine. A light flywheel and crank pulley will also help put down the power
Your gonna want something to tune with as well, these cams are all abotu tuning if you can get a good tuner you can almost idle like stock. And for cam gears i would just recommend anyting 5bolts will do..
