Crower 403's on LS
Old Dec 6, 2003 | 07:09 PM
94B18B1Teg's Avatar
Default Crower 403's on LS
I want to get crower 403's with ti valve springs & retainers, cam gears. I will also be getting some porting and polishing done, chipping the ecu, and getting a header. I was wondering what needs to change as far as intake manifold, and throttle body, and will I touch 14's? PS. I'm doing all the work myself, any help on what do with my stock valves, polishing or grinding, and if I need new ones? Thanks.
Old Dec 6, 2003 | 07:18 PM
91tegrals's Avatar
up grade youre pistons and you should hit 14s might be possible with wat you described...
Old Dec 6, 2003 | 07:27 PM
94B18B1Teg's Avatar
Default Re: (91tegrals)
If I don't upgrade the pistons, if I had a chipped ECU giving me a higher RPM range, do I need ARP rod bolts? cause if I NEED ARP rod bolts for a little bit higher RPM, then I will get pistons just because I've got the damn thing apart. You suggest 11:1 comp pistons or around there? After pistons, I'll prob need a new intake manifold...this is a **** load of money we're talking. I wonder if the ET's will be worth it. I just wanna touch 14's, if I end up doing like low 14's high 13's ...I'll be really happy though, please reply back, I need opinions.
Old Dec 6, 2003 | 07:46 PM
JGDA9's Avatar
You should be in 14's with that setup pretty easy... The head alone dropped my time by 1sec.
Old Dec 6, 2003 | 08:14 PM
94B18B1Teg's Avatar
Default Re: Crower 403's on LS (94B18B1Teg)
bump for the night time opinions? haha.
Old Dec 6, 2003 | 08:49 PM
StyleTEG's Avatar
You don't even need aftermarket cams to hit 14s on an LS.
With the right boltons and weight reductions its possible.
Old Dec 6, 2003 | 10:14 PM
djay86's Avatar
Default Re: Crower 403's on LS (StyleTEG)
15.2 stock motor/ chipped ecu/ bald tires/ 150k on the clock/ cai/ open header/
Old Dec 8, 2003 | 06:59 PM
91tegrals's Avatar
that 15.2 was in a g2...
Old Dec 8, 2003 | 07:17 PM
random-strike's Avatar
i picked up a b20b head & intake manifold for really cheap.
i used the b20b intake with the b18a1 tb. b20b intake manifold was way way bigger than the b18 one. the runners are biiig. they're as big as a b16a, and the intake ports on a b20b are about as big as a b16a head.
kinda looks like a b18b head, but its a b20b and the intake
Old Dec 8, 2003 | 07:31 PM
88civicHB703's Avatar
nice... setup random strike
NotSoJDMNH
Feb 16, 2014 07:40 PM
95turbogsr
Jun 27, 2005 05:27 PM
r3v da t3g
Mar 26, 2005 08:06 AM
erebunicrx
12
Nov 5, 2004 07:32 PM
Si2kblue
Nov 27, 2001 02:01 PM
