Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   crower 403 question (https://honda-tech.com/forums/acura-integra-6/crower-403-question-2516663/)
89canefighter Mar 5, 2009 04:31 AM
crower 403 question
im thinking of running the 403 cams after lots of thinking and reading. i am wondering if i keep the stock rev limit would i be able to get away with stock valve springs/retainers or no. i have done a lot of research on this topic and i cant get a definitive answer. so i am asking you guys
Can you get away with running the crower 403 cams with stock springs if you utilize the stock rev limiter.
phaphon Mar 5, 2009 12:27 PM
Re: crower 403 question
i had afriend with the stage 2's did him good but i have them in my car i just got it running today and my shit knocks hella loud
phaphon Mar 5, 2009 03:28 PM
well i just redid my valves they sound better i but i still would suggest the valve springs and retainers though...but damn it pulls hella hard
tilegend Mar 5, 2009 04:09 PM
damn that must be hella crazy....
89canefighter... i found a definitive answer.... on crower's website.
http://crower.com/cat/import/honda/cams/b18ab.shtml
62403-2
Stage 2 - Street/Strip package.
Most popular "all motor" profile.
Requires #84162 kit. 1000 to 8000+ rpm (15-18 hp).
Dyno Results
Si-rdc2 Mar 5, 2009 09:40 PM
i`m using the brain cower stage 2 on my ls with stock springs just make you adjust your valves right i adjusted them to the lowest it say for adjustment i`m going to get the dual valve springs so i can go to 7500 8000 rpms
Tim2179 Mar 6, 2009 06:25 AM
You can use the stock valve train and keep the stock rev limit - but that would be defeating the purpose of the cam. If you do that, you car will only be louder, idle a bit lower (you can adjust that) and not be any faster. My 1/4 mile times confirm this. One thing the 403s will do is drown out the sound of your intake whistle...
<-- has 403s, stock valve train, stock rev limiter.
