Correct valve spring install height?
Old Mar 5, 2002 | 05:52 AM
StinkyTofu's Avatar
Default Correct valve spring install height?
Does anyone know the correct install height for skunk2 valve springs? And how do you measure your valve springs?
Old Mar 5, 2002 | 07:45 AM
rtype11's Avatar
Default Re: Correct valve spring install height? (B-18C1)
same as stock, refer to haynes or chiltons manual, it is very hard to measure on our heads as it is soo tight. I have yet to shim any of mine, you can usually get away with measuring open and closed seat pressure and if they are fine dont worry too much unless you have a crazy lift camshaft.
Balor_Gr
May 4, 2018 12:03 PM
SomeDude56
Jan 24, 2006 12:09 PM
westcoaststyle
Apr 6, 2005 02:34 PM
TRuST
Sep 2, 2004 03:29 PM
