Corner light question??
Old Jul 12, 2008 | 12:27 AM
simplypinoyy's Avatar
Default Corner light question??
My left turn signal works and both lights light up when I use the turn signal but when I use the turn signal to the right it acts as if I have a bulb burnt out. I look at the corner lights from the outside and only one light works. The weird thing is that when I turn on my headlights both lights turn on. Is this just a matter of changing bulbs or a wiring problem? Im not familiar with integras, this is my first one.
Old Jul 12, 2008 | 09:50 AM
Default Re: Corner light question?? (simplypinoyy)
Bump.... need an answer
Old Jul 12, 2008 | 10:00 AM
BTT's Avatar
BTT
Do you mean that your left turn signal works and both <U>headlights</U> work?
If thats what you mean and only your right turn signal isnt working, it could be the: bulb, or wiring. I was going to say it might be a blown fuse but i doubt it because when a fuse blows, then usually that cars whole side of lights stop working.
Old Jul 12, 2008 | 11:43 AM
Default Re: Corner light question?? (BTT)
yeah both headlight works but the right corner light lights up but it only one out of the two lights (since there are 2 in the corner lights) on the corner light blinks.
Old Jul 12, 2008 | 02:38 PM
I just replaced the 1157 bulbs on both corner lights and the right corner light works fine now when using the turn signal but the left corner light still doesn't light up when i have the headlights on or when the parking light is on, but the turn signal for the driver side works correctly.
Old Jul 12, 2008 | 04:05 PM
spidy3's Avatar
make sure the wires are attached to the connector that the bulb goes in. had same issue and my wires were corroded and broke right off plastic connector. if thats fine put some dialectric (spelling?) grease in the socket where the bulb sits and see if that works. its probably just a bad connection if you already replaced bulb and its doing same thing.
Old Jul 12, 2008 | 04:22 PM
Tegraracer90's Avatar
Default Re: Corner light question?? (spidy3)
yeah it sounds like a ground problem..lights will do some weird things if the ground is messed up...check wires and such and all connections
Old Jul 12, 2008 | 11:59 PM
Default Re: Corner light question?? (Tegraracer90)
I'll check that later when I wake up... I just hate the look of it at night because one section of the front driver side corner light is half lit... thanks for the input! Also that corner light works properly when in use... both of the lights within the corner light lights up when in use.
rawrjaay
Aug 24, 2022 02:38 PM
invader_zim
Mar 28, 2012 09:57 PM
OneFire
12
Jun 30, 2011 06:38 PM
Killtodie
Honda Civic (2001 - 2005)
Jun 27, 2008 03:46 PM
Edgemingsr
Aug 18, 2004 11:45 AM
