Coolant leak?
Old Feb 12, 2003 | 12:43 AM
tylermaxon's Avatar
Default Coolant leak?
I have a coolant leak, and when i look at my block, theres coolant all around where the oil pan and block come together? if the gasket isnt good there, does coolant leak? becuase i just had my oil pan changed at this garage. idk, if someone knows anything that would be cool.
Old Feb 12, 2003 | 05:03 AM
JimBlake's Avatar
Default Re: Coolant leak? (tylermaxon)
Shouldn't be any coolant connections down there. I'd clean everything off real good & look for it leaking somewhere above & running down.
Which side of the engine is it on?
Old Feb 12, 2003 | 07:05 PM
tylermaxon's Avatar
Default Re: Coolant leak? (JimBlake)
on the right side
Old Feb 13, 2003 | 04:00 AM
JimBlake's Avatar
Right side of the car...
Both radiator hoses are over there, thermostat gasket, couple temperature sensors are screwed into the coolant passages, etc...
Towards the backside you've got that funny tube going over to the water pump, its got an o-ring.
Seems like the heater hoses & oil cooler hoses are more towards the middle backside, but I don't quite remember.
None of that stuff is down low like the oil pan, but like I said its probably running down from where the real leak is located.
Chads7
10
Sep 25, 2010 11:22 AM
oranginal
Mar 30, 2009 07:39 AM
dc2long
Jun 16, 2006 11:26 AM
Raymund
Aug 8, 2003 07:41 PM
