Coolant Flush?
Old Nov 29, 2004 | 12:43 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Coolant Flush?
I just had the coolant drained and flushed at the dealer (along with a lot of other things). Before I left the dealer the coolant in the overflow tank was at the max line. However, after 35 miles of driving the overflow tank was empty . Should I worry about this and should I top off the overflow tank asap? Thanks
Old Nov 29, 2004 | 12:47 PM
purplegsr's Avatar
Default Re: Coolant Flush? (FrostyDC4)
No big deal, just top it off with a mix of coolant and water. Usually this happens because air bubbles escape or they forgot to move the temp switch, so the heater core was closed when they were filling it.
Once you fill it, you should notice it go down a bit more after driving it, just keep topping it off until it stays consistently at the max line.
Old Nov 29, 2004 | 12:49 PM
94ls's Avatar
after you've drained and refilled... it may take a bit for it too actually cycle through.... just keep it topped off and watch for it. the dealer should have ckd for that before they let you take it. it's no biggie tho..i did a coolant flush myself a few weeks back and i had to refill the reservoir tank a few times before it finally stopped going through. no worries guy just keep an eye on it. if it bothers you that much... let the car sit parked overnight and ck for any poss leakage the following morning...but i doubt it will be an issue
furious94ls's Avatar
Default Re: Coolant Flush? (purplegsr (Exospeed))
Go back, have em top it off with the 50/50 mix they have. Why spend the $$ twice?
Old Nov 29, 2004 | 01:16 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Coolant Flush? (furious94ls)
Ah I see. Thanks!
<----------- who is going to top off his overflow tank
JacobD
Honda Civic (2001 - 2005)
Sep 12, 2017 06:18 PM
BadassEFdriver
Jun 20, 2011 06:12 PM
CXtypeR
Jan 26, 2007 08:10 PM
Integra Integra
Mar 22, 2006 06:57 PM
Pat
Jan 27, 2002 05:12 PM
