compression ratio???
Old May 29, 2004 | 09:38 PM
allmtrdc4's Avatar
Default compression ratio???
i am building an all motor nonvtec teg ls motor and i am wanting to put type r pistons in and i was wondering if anyone knew what my compratio would be i want around a 12.0:1 and i have heard that just type r pistons will do that but i need to know so i need to know if i need to shave my head or not to get to 12 thanks keith
Old May 29, 2004 | 09:54 PM
asubennett's Avatar
Default Re: compression ratio??? (allmtrdc4)
With JDM type R piston which have almost a 5.5cc dome
Your compresion ratio would be 10.9 to 1.
This is assuming your deck is stock. Your head is not shaved. And the combustion chambers on your LS head are still the stock 45cc.
Also this is calcualted with .5mm over pistons. Hope this helps
CTR pistons and a two layer head gasket will get you 11.8 to 1.
The Up Garage
11
Apr 8, 2006 12:32 PM
nyteflyte2003
Jan 24, 2005 10:13 PM
JDubya
Feb 21, 2003 09:56 AM
MOTOR R
Nov 26, 2001 03:29 PM
MXPX
Jun 20, 2001 06:33 PM
