COILOVERS
Old Jul 7, 2004 | 02:55 PM
VIETTEC's Avatar
New User
Default COILOVERS
I ave a 90 integra ls and i was wondering if the coilovers for a 94 and up integra fit on my integra... pls let me know or if u know where i can find info on it let me know.... thanx
Old Jul 7, 2004 | 05:37 PM
nintylsteg's Avatar
Default Re: COILOVERS (VIETTEC)
im not for shure iv heard people say they do and some say they dont. im assuming the spring rates would be diff. what coils are you looking at?
Old Jul 7, 2004 | 06:19 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: COILOVERS (nintylsteg)
What type of coilvers are you looking at? True full coilover systems that include the shock (with a threaded body) and the spring? Or are you looking for a sleeved coilover setup that is cheaper?
The setup with the sleeves will fit the previous generation Integra, however, as nintylsteg said, the spring rates might be different. If anything, the spring rates on the newer Integras should be harder. You will most probably get a stiffer ride if you put them on a previous generation Integra.
Not 100% sure on that though, but I do know they will fit. (sleeved setups, that is). As for the full on systems that cost up to several thousand dollars, I'm not sure how the suspension is on the previous generation Integras. I do believe the shock is mounted slightly different, so it probably won't work.
Old Jul 7, 2004 | 06:40 PM
SuzukaBlueAP2's Avatar
I don't know if the spring rates would be different on the sleeve setups or not. Atleast the cheaper ones....Ground Controls might vary...but stuff like the R-1 and cheap setups like that, they are probably all the same. And I know those sleeves fit 90-01 Integras
Old Jul 7, 2004 | 07:33 PM
VIETTEC's Avatar
New User
thanx for the info guys...i really really appreciate it
any sites where i can check for sure?
champLSinteg
Suspension & Brakes
Feb 25, 2008 11:41 AM
dpw41285
Nov 27, 2004 09:59 AM
pinoyboy204
May 1, 2004 10:07 PM
yy23
Dec 8, 2003 08:53 PM
allmotorchick
Nov 3, 2003 04:58 PM
