coil test
Old Mar 16, 2006 | 02:41 PM
jjdickm's Avatar
Default coil test
how do you test a coil on a 1992 acura integra ls. I have a ohm meter and I pulled the distributor. I was going to go buy a new distributor but I want to make sure that is my problem.
Old Mar 16, 2006 | 03:50 PM
Ruben19's Avatar
you dont need a new distibutor if your coil is bad.
to test the coil
primary test should read 6-7ohm
secondary test should read 14.5-16 ohm
Test your igniton control module if the coil is good.
Old Mar 16, 2006 | 04:20 PM
jjdickm's Avatar
Default Re: (Ruben19)
secondary is reading 10ohm and primary is giving me less than an ohm
how do you test the module
Old Mar 16, 2006 | 07:54 PM
Ruben19's Avatar
i think the coil is bad.
should be reading more than 1 ohm in the primary test.
i test my module with a special tool at school...
nickelz34
Jan 2, 2013 04:42 AM
craiger28
54
Aug 17, 2010 07:20 AM
hfrex
Jan 8, 2009 02:43 PM
aalb1
Aug 7, 2005 10:50 PM
pushinlsteg
May 12, 2005 09:38 AM
