code 43 need a little help!
Old Jul 11, 2016 | 09:59 PM
freshazfuk's Avatar
Default code 43 need a little help!
a little background on the car:
1990 integra ls manual
jdm b20b 21000 mi
ys1 trans
skunk 2 intake manifold
skunk2 70mm throttle body
everything else is stock including fuel rail and ecu pr4 i believe......
well i was only getting a code 17 which i know is a speed sensor issue which i replaced my vss hooked everything up right later to find out that i need to take off the speedo and attach the cable back to it.....just havent done it yet.....
Recently i gave it a little test and made a two hour drive to see how it does.....well everything went good except while i was there i got a code 43 which i read was a o2 sensor or something to do with the fuel.....i noticed when im driving the car kinda bogs when i just cruise but when i give it alot of gas it goes and feels like nothings wrong with it.....has anyone had this code 43 problem???and how did you fix it?? i know i need to chip and do the conversion of my ecu to obd1....i was wondering if that would be the issue right there but i wanted to ask around here to see if anyone has had the same issue???/any input would be very appreiciated!!!
Old Jul 12, 2016 | 02:40 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: code 43 need a little help!
replace the O2 sensor
Old Jul 12, 2016 | 03:52 AM
freshazfuk's Avatar
ok i have dc headers so no 02 sensor there i only have the one after the headers in the back of the engine....is that upstream or downstream......downstream right?
Old Jul 12, 2016 | 04:34 AM
wunfstgsr's Avatar
Loved
Community Favorite
your running a OBD1 ecu right?
Does the header have a hole thats been pluged with a flat bolt or is there no spot for a O2 sensor on the header?
So your saying the O2 is after the header so its on the cat. It should be bank 1 sensor 1 upstream.
Old Jul 12, 2016 | 12:47 PM
freshazfuk's Avatar
first of all i just bought the car and it was with the swap(b20b).....its running a obd0 ecu pr4.....it has no cat...it has no hole for the 02 sensor in the headers(dc) heres a few pictures of the header and the o2 sensor it has
Monkeyz1
Sep 5, 2008 08:18 AM
rasta420
43
Feb 16, 2004 12:39 AM
.ShawnD.
Jan 28, 2004 03:34 PM
turboex
May 16, 2002 05:13 PM
REDBARON
Feb 18, 2002 08:06 AM
