Clutch problem ?
Old Nov 23, 2006 | 05:00 PM
sihonda's Avatar
Default Clutch problem ?
alright my car 2 time the pedal has felt like it lost pressure, more like the pedal has more play bc i always have pressure, it isnt as high as it use to be, i just serviced my slave cylinder bc it was leaking, another thing to add to the loss in hight and stiffness of the clutch pedal, when i lauch the car or shift to 2nd it dosent bite as much or hard, i dont get the dash shaking
oh i have a exhedi clutch and fly wheel
plz help
Old Nov 23, 2006 | 07:00 PM
aaronISthrowed's Avatar
Default Re: Clutch problem ? (sihonda)
I can't really understand you but did you check to see if there was fluid in the clutch MC?
Old Nov 24, 2006 | 05:04 PM
sihonda's Avatar
Default Re: Clutch problem ? (aaronISthrowed)
yes and it hasnt moved, it is right at max
i am guessing it is a perssuer plate problem, bc of the lose in hight of the pedal
Old Nov 24, 2006 | 05:28 PM
brettdc1's Avatar
i was having serious problems after replacing slave and master cylinders and couldnt figure out why the clutch would be tight some days and have a lot of free play on other days. usually when it was warm the clutch would be much stiffer. well my uncle is a car nut and i took it to him. we bled the snot out of the clutch line then finally figured out that the master cylinder resevoir was way over filled by yours truly and when the liquid expanded due to heat it had nowhere to go and was causing the clutch to disengage just a little bit all the time, therefore not causing as much bite on the shift. Look hard all the way around your master cylinder resevoir and look for the max fill line it doesnt jump out at you.
food for thought^^^^^^^^^^
Old Nov 24, 2006 | 05:43 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Clutch problem ? (brettdc1)
try re-bleeding the system and getting some language / spelling lessons...
K3VL4R
Nov 18, 2012 03:39 PM
garyc17
Dec 18, 2006 10:24 AM
danteisme
May 20, 2005 08:26 AM
LOC714
Sep 23, 2004 12:34 PM
blkgsr03
14
Sep 16, 2004 05:19 AM
