Clutch issues
Old Aug 20, 2009 | 05:19 AM
jfresno's Avatar
Default Clutch issues
I'm having trouble w/ my 99 gsr... the clutch doesnt engage until the pedal is depressed about 3/4 the way. When it's cold its sometimes difficult to get it into gear. There is absolutly no slipping though, plenty of grip. Does it need adjusting or could it be a more serious problem? Any help would be much appreciated!
Old Aug 20, 2009 | 05:29 AM
civicgsr's Avatar
Default Re: Clutch issues
Do you mean disengage?
Has this been a gradually increasing problem or all of a sudden.
You could play with your pedal end play. Also, you may have lost a spring in your clutch disk...but usually the problem is a lot worse.
http://importnut.net/clutchcomparo.htm Check the section on OEM clutches.
Old Aug 20, 2009 | 05:39 AM
jfresno's Avatar
It may have been very slowly happening. There also tends to have a slight sqeak when the pedal pressed and depressed, only when its up to temp. If it were a lost spring or a pressure plate malfuntion wouldnt there be slippage?
Old Aug 20, 2009 | 06:14 AM
civicgsr's Avatar
Actually, if you looked at the picture of the broken spring on my site, you would see that it's the "damper" spring.
What ends up happening with that kind of failure, is that the spring lodges itself between the disk and pressure plate. Long story short, the clutch ends up being engaged no matter what you do with the pedal.
As I'm thinking about it, I think your problem is in the clutch slave or master cylinder. It could just be air in the line but it may be a problem with one or the other. The squeak that you hear is probably nothing more than the piston in the slave cylinder squeaking against the clutch release arm. A dab of grease will cure that.
Old Aug 20, 2009 | 11:31 AM
jfresno's Avatar
Any simple way to make sure the cylinders are functioning properly?
alexsneesby
Aug 18, 2010 12:11 PM
OG SHG_EM1
Oct 30, 2007 07:50 AM
ek_b16
Jan 8, 2005 04:42 AM
