Which clutch
Old Oct 14, 2005 | 06:27 PM
00CivicGirl's Avatar
Default Which clutch
Frind of mine has a 93 GSR however he has a 95 Gsr motor..we are trying to find out what clutch he needs to get b/c it seems as if his is going out. From what I can understand, its a YS1 jdm tranny (hydro) what clutch would fit this tranny or is there some #s i can get off the casing and post to maybe figure out EXACTLY what tranny it is..
Old Oct 14, 2005 | 07:38 PM
Kendall's Avatar
All YS1 trannys are cable. You'll need any clutch for a 90-93 Integra.
Old Oct 14, 2005 | 08:04 PM
Rajin's Avatar
Default Re: (Kendall)
Exedy has some good units. Try them out.
Old Oct 15, 2005 | 05:10 AM
gsrvtec2's Avatar
Default Re: (Rajin)
ACT pressure plate
Old Oct 15, 2005 | 08:04 PM
12secteg's Avatar
Default Re: Which clutch (00CivicGirl)
Im running a Clutchmasters FX100 on my 170 whp LSVTEC and it holds excellent. The clutch enguagement is smooth and not difficult like ACT's are. I had a 4 puck on the b16 powered 92 hatch i used to have and it sucked, always chattered and squeeled. The clutchmasters is very streetable and holds up to 250 hp, i have it on my cable GSR tranny
Old Oct 15, 2005 | 08:15 PM
Default Re: Which clutch (12secteg)
yea he is looking to upgrade the clutch but the main prob was that he didnt know which clutch to get as far as year and model
Old Oct 15, 2005 | 08:34 PM
FULLY_BUILT_NA's Avatar
dont get exedy
Old Oct 15, 2005 | 09:59 PM
sirg-vtec's Avatar
Default Re: (FULLY_BUILT_NA)
I have ACT w/ Prolite No comments.
Old Oct 15, 2005 | 10:58 PM
IVI's Avatar
IVI
Default Re: (sirg-vtec)
ive had an act, clutchmasters, and currently on exedy.
the exedy is the stage 1, which is supposed to be almost like stock.
the other clutches i had were performace clutches, 4 puck.
i like the exedy, because for a daily driver, im looking for a comfortable car.
Old Oct 15, 2005 | 11:30 PM
DarkDragon's Avatar
Default Re: (IVI)
well any 90-93 clutch WONT work. The 92-93 clutches have a larger spline drive since those year tegs input shaft was larger. U need to find out what year trans it is and buy a clutch for that trans. See if its cable or hydro since the throwout bearings are different. If its the stock 93 GSR tranny then buy a clucth for that year teg since all b series flywheels are the same and interchangable
Old Oct 15, 2005 | 11:34 PM
blakezilla06's Avatar
act
Old Oct 16, 2005 | 06:52 PM
Default Re: (DarkDragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkDragon &raquo;</TD></TR><TR><TD CLASS="quote">well any 90-93 clutch WONT work. The 92-93 clutches have a larger spline drive since those year tegs input shaft was larger. U need to find out what year trans it is and buy a clutch for that trans. See if its cable or hydro since the throwout bearings are different. If its the stock 93 GSR tranny then buy a clucth for that year teg since all b series flywheels are the same and interchangable</TD></TR></TABLE>
yea im tryin to get him to get some #s or something off the trany so that i can try to find out which tranny it is...its a cable i do know that
Old Oct 16, 2005 | 07:49 PM
Default Re: (00CivicGirl)
ok this tranny code is S1-1091436 I am assuming by this that its an LS tranny mated with a 95 gsr motor
which clutch flywheel and axles should be used (he just snapped an axle as well)
Old Oct 17, 2005 | 08:17 AM
anyone?
Old Oct 17, 2005 | 09:56 AM
projectTeG's Avatar
if he has the ys1 he needs the larger splined 92-01 clutch
midnite_B16
Sep 8, 2007 09:48 AM
00CivicGirl
Dec 29, 2005 02:03 PM
civicuser
Feb 25, 2004 09:21 AM
wizzards581
Apr 6, 2003 10:54 AM
