Cluster Issue
Old Jul 15, 2016 | 06:58 AM
TeeKayy's Avatar
Default Cluster Issue
So having an issue with my 97 LS cluster lights. The cluster was swapped with a ITR USDM cluster.
My tail lights, check engine light, blinker lights, and dimmer switch all work just the illumination for the speedo and tach aren't working. The fuses isn't blown either.
I can apply power directly to the dash with it out and the lights come right on but when I put the harness in they do not come on.
There is an aftermarket stereo installed, so I am kind of lost.
Old Jul 16, 2016 | 07:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Cluster Issue
If other illumination lights are working then it has nothing to do with the aftermarket stereo.
My guess is the cluster plug(s) are not pined properly, there should be two(2) leads for the cluster lights, a red/black, [power] and a red, [ground from Dash Lights Brightness Controller] make sure those two leads a pinned properly for the cluster, they must go to the same place you supply power and ground too to get the illumination to work with cluster out. 94
Old Jul 18, 2016 | 12:10 AM
wunfstgsr's Avatar
Loved
Community Favorite
Maybe you need to swap the green electric film on the back with the ls one.
Old Jul 19, 2016 | 05:14 AM
TeeKayy's Avatar
Finally figured out the issue, after tracing the cables from the dash cluster the wire was cut and never soldered back. SMH I just don't understand what some people do with cars before I get them.
Old Jul 19, 2016 | 11:08 AM
JamesChurch75's Avatar
This happened to mine and it worked for me.
worx
Nov 7, 2012 06:10 AM
furiousbob
Dec 14, 2008 11:46 PM
ge_ej1
Jan 31, 2008 09:00 AM
snuggles
Jun 10, 2004 08:47 PM
